Subject: Archiver getDataAtTime and getData endpoints have a timestamp discrepancy
From: "De La Paz, Elena via Tech-talk" <[email protected]>
Date: Mon, 9 Aug 2021 21:11:40 +0000
Hi all,
I have a question about using the different endpoints and the timestamp resolution of the archiver. Here is the situation that is confusing me:
  1. I make a request to the getData endpoint for some <PV> that returns multiple values, each accompanied by a secs and nanos field indicating when the value was updated
Example response for pv ID:  [{ val: “2”, secs: “1627576833”, nanos: “342322864”}, {val: “3”, secs: “1627576922”, nanos: “563728637”} ]
  1. When I make a request to getDataAtTime where the at parameter contains the full returned timestamp, down to the nanoseconds, I get the record value before:
Example request: <ARCHIVER DATA ENDPOINT>/getDataAtTime?at=<UNIXSECONDS FOR SECS OF VAL 3>.563728637 -d [“ID”]
Example response: { “ID”: “2”}
This occurs over shot intervals, so time zone issues are not the underlying cause. Is there some difference in the time resolution of the different endpoints? Is this a quirk of the archiver? We are doing a work around by rounding up to milliseconds, but it is confusing that the timestamp returned in nanoseconds can’t be used precisely in getdataattime
Thank you,
Elena De La Paz
Prev: Re: db/streamdevice/proto Agilent 34970A Dunning, Michael via Tech-talk
Next: RE: Getting started talking to a device Leblanc, Gregory via Tech-talk
Prev: Re: Phoebus image widget info Siddons, David via Tech-talk
Next: Great Career Opportunity for Particle Accelerator Instrumentation Physicist/Engineer Nicholas James Meyler via Tech-talk
