This is the GUI to define how the fit is to be done:
There are parameters to control the background fit. Each peak is defined with a string like “ag ka” which looks up the known energy of the Ag K-alpha line in a library.
In this case the peaks fit were:
X-ray peaks: Ag (Ka,
Kb), Pb (Ka1,
Ka2, Kb1)
Ag pileup peaks at ~44 and ~47 keV
Cd109 88 keV and Co57 122 keV gamma peaks
The energies of all of the peaks except the pileup peaks were fixed, only the 2 global energy calibration coefficients were optimized. For the pile-up peaks the energies were also optimized.
The FWHM of each peak was optimized, rather than using a global FWHM fit.
The amplitude of each peak was optimized.
This is the output of the peak fit:
Fit of Dante:mca1
Real time (seconds): 60.00
Live time (seconds): 51.99
Initial FWHM offset, slope: 0.150000 0.000000
Optimized FWHM offset, slope: 0.150000 0.000000
Initial energy offset, slope: -3.077860 0.032839
Optimized energy offset, slope: -3.084599 0.032837
# Iterations, function evals: 0 94
Chi squared: 1.036725e+009
Status code: 2
Error message:
Peak Energy FWHM Area Background Area/MDL Area/Bkg
ag ka 22.104 0.5341* 135519.0 4757.0 655.0 28.5
ag kb 24.987 0.6266* 30379.3 5439.0 137.3 5.6
ag pu1 44.226* 1.3835* 299.7 2518.0 2.0 0.1
ag pu2 47.479* 4.0529* 402.1 6400.0 1.7 0.1
pb ka1 74.956 0.6177* 12808.8 1613.0 106.3 7.9
pb ka2 72.794 0.5894* 7246.5 1474.0 62.9 4.9
pb kb1 84.922 0.9537* 4914.5 1648.0 40.4 3.0
cd109 g1 88.040 0.7356* 5387.2 1326.0 49.3 4.1
co57 g2 122.061 0.6411* 34850.2 871.0 393.6 40.0
This information is also written to a file that can be easily imported into Excel.
The IDL program can be run for free on Linux, Windows, and Mac using the IDL Virtual Machine.
In 2002 I ported the IDL program to Python, with all of the features described above. It was put into production at the Swiss Light Source at PSI.
Unfortunately those were very early days with Python, and I bet on the wrong horses in terms of which packages to use. I used Numeric rather than NumPy, and I used BltPlot for the graphics. When IDL released
the Virtual Machine so my users could run it at home for free I stopped developing the Python code. It won’t run now, but it actually would not be a huge job to convert it to modern libraries. If you are interested I would suggest contacting PSI to see if
they are still using it, and have perhaps done the conversion already.
The Python code is on Github here:
https://github.com/CARS-UChicago/EPICS_Python_old
The IDL code is on Github here:
https://github.com/CARS-UChicago/IDL_EPICS_MCA
The IDL code in a form that can be run in the free IDL Virtual Machine is here:
https://cars.uchicago.edu/software/pub/idl_mca.tar
Hi Mark, Everyone,
I have used the mca record to connect to a Bruker/Rontec Silicon Drift Detector. It works nicely, as does the supplied example GUI in Phoebus.
I would like to allow my users to specify calibration to scale from mca waveform bin to energy, and then be able to specify regions of interest in terms of energy rather than bin
start and ends.
I saw in the documentation that it’s mentioned an IDL app exists to do this, and that it had been ported to python. (https://cars.uchicago.edu/software/epics/mcaDoc.html)
I think this is now in the “Legacy” folder of epicsapps
https://github.com/pyepics/epicsapps/tree/master/Legacy/MCADisplay I could not get it to run.
I would like a phoebus based display that did what that the mcaDisplay application sounds like it does/ did.
What tools are other people using to interact with the mca record? Do I need to make extra records to hold the converted waveform, and ROI’s or can I deal with this just by conversion
in the display tool?
Many thanks,
Will
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Jan Lüning (Sprecher), Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
