Hi Ru,
Thanks for pointing this out. Could I ask you to please create a Github issue here: https://github.com/epics-modules/mca/issues
Thanks
-----Original Message-----
Sent: Wednesday, August 11, 2021 3:46 PM
To: [email protected]
Cc: Mark Rivers <[email protected]>
Subject: MCA module's Amptek USB driver fails to connect
Hello,
This is mostly directed at Mark Rivers but might be of some use to someone in the same situation as me.
I tried to use the synApps mca module R7-9 to control some Amptek
PX5 SDD readout electronics over USB (Amptek docs say the ethernet is 10-baseT... haven't had time to test transfer rates to see if this is still true). I couldn't get the driver to connect, then traced the problem to the function "drvAmptek::connectDevice()" failing on a "hostToIPAddr()" call that fails because a valid IP address was not given (actually is left blank for USB devices). I got around it by checking if "addressInfo_" is empty, and that got the app working so that I could to some test data acquisition. But it now occurs to me that the entire chunk of code prior to checking "directMode_"
should be in the "if( interfaceType == DppInterfaceEthernet)" block.
I haven't tested this yet, but it seems more appropriate.
ru
Ru Igarashi
e-mail: [email protected]
phone: 1 306 657 3751
address:
Canadian Light Source
44 Innovation Boulevard
S7N 2V3 Canada
- MCA module's Amptek USB driver fails to connect Ru Igarashi via Tech-talk
[no subject] yue zongyang via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
