Subject: Re:
To: yue zongyang <[email protected]>
Date: Thu, 12 Aug 2021 11:40:27 +0000
Hi Zongyang,
What version of the motor record are you using?  The current master branch of the motor record does not contain a field called CENE.
https://github.com/epics-modules/motor/blob/master/motorApp/MotorSrc/motorRecord.dbd
Is this something that was locally added to the motor record?
From: Tech-talk <[email protected]> on behalf of yue zongyang via Tech-talk <[email protected]>
Sent: Thursday, August 12, 2021 4:03 AM
To: [email protected]
Subject:
I is writing motor device driver based on Model 3.
But I meet some problem which about rewriting WriteInt32 (asynUser *pasynUser, epicsInt32 value) function.
However, I changed the value of $(motor).CENE field in motor OPI, my WriteInt32()  function cann’t be called.
And the value of other fields changed can call this function.
My WriteInt32() function is  as follow:
asynStatus PDICLController::writeInt32(asynUser* pasynUser, epicsInt32 value)
       int function = pasynUser->reason;
       int status = asynSuccess;
       PDICLAxis* pAxis;
       static const char* functionName = "writeInt32";
       pAxis = this->getAxis(pasynUser);
       if (!pAxis) return asynError;
       status = pAxis->setIntegerParam(function, value);
       epicsPrintf("test :104 line :The function name:%d and the value :%d\n",function,value);
       if (function == PDICLJoggingPosMethod_)
              if(value!=0)
                     status = pAxis->Jogging_move_pos();
       if (function == PDICLJoggingNegMethod_)
              if(value!=0)
                 status = pAxis->Jogging_move_neg();
       else {
              // Call base class method
              status = asynMotorController::writeInt32(pasynUser, value);
       pAxis->callParamCallbacks();
       return (asynStatus)status;
When I change the state of $(motor).CENE field , just the motorUpdateStatus_ function that is called which mark is 26
and the motorClosedLoop_ function cann’t be called which mark is 19.
Mennwhile I test the motorStop_ function which mark is 4.
The test result of the shell of ioc is as follow
epics> test :104 line :The function name:26 and the value :0
test :104 line :The function name:4 and the value :0
I see other motor module’s device driver have done as same.
What’s going wrong about my code?
Any suggestions or comments would be appreciated.
Best regards!
Zongyang yue
[no subject] yue zongyang via Tech-talk
Prev: [no subject] yue zongyang via Tech-talk
Next: Re: HiPace control via EDU TC 400 Marco A. Barra Montevechi Filho via Tech-talk
Next: Re: Mark Rivers via Tech-talk
