Subject: RE: IOC up, but can't connect via channel access
From: "Daykin, Evan via Tech-talk" <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 13 Aug 2021 17:07:19 +0000
Hi, We’ve solved this. Kudos to J. Priller for pointing out that the channel access security definition it was looking for was not present! I didn’t know this was the behavior in the case of a missing CAS file.
-Evan
Sent: Friday, August 13, 2021 12:42 PM
To: Daykin, Evan <[email protected]>
Subject: Re: IOC up, but can't connect via channel access
[EXTERNAL] This email originated from outside of FRIB
On Aug 13, 2021, at 11:32 AM, Daykin, Evan <[email protected]> wrote:
>Is Puppet running them inside a container?
No container, ProcServ is just running them on the host machine.
> The iocsh command ‘casr 1’ will show you what the network interfaces are that the CA server is listening on and sending beacons to.
Ah, this is the command I was looking for. The result comes up completely blank.
Then it sounds like you may need to tell the system that these IOCs are allowed to use the network. I’m slightly surprised that you didn’t get a warning from iocInit if the server doesn’t have any networks to connect to, but maybe it doesn’t do that. I would expect your casr output to look something like this (the interest level 1 is important BTW):
epics> casr 1
Channel Access Server V4.13
No clients connected.
CAS-TCP server on 0.0.0.0:5064 with
    CAS-UDP name server on 0.0.0.0:5064
Sending CAS-beacons to 2 addresses:
    10.234.56.255:5065
    164.202.224.110:5065
- Andrew
Sent: Friday, August 13, 2021 12:22 PM
Hi Evan,
On Aug 13, 2021, at 10:48 AM, Daykin, Evan via Tech-talk <[email protected]> wrote:
I have just restarted a set of IOCs after puppetizing their configuration. They are accessible via a Telnet ProcServ connection, and dbpf shows everything populated and defined. However, if I try to use caget, caput, etc. there is no connection. What are the possible causes of this? EPICS_CA_AUTO_ADDR_LIST seems to be set as “YES” and other IOCs I haven’t touched are still reachable.
Is Puppet running them inside a container? If so you need to configure that to share the host’s network (or run a CA Gateway between the host’s network and the internal container network, but I don’t really recommend doing that).
- Andreww
Complexity comes for free, simplicity you have to work for.
IOC up, but can't connect via channel access Daykin, Evan via Tech-talk
Re: IOC up, but can't connect via channel access Johnson, Andrew N. via Tech-talk
Prev: Re: IOC up, but can't connect via channel access Johnson, Andrew N. via Tech-talk
Next: Re: IOC PVA on mTCA CPU requires environment variables to be set Michael Davidsaver via Tech-talk
Next: ADCameralink on Linux Дмитрий Прощенко via Tech-talk
