Subject: exampleCPP Makefile questions
From: "Wang, Andrew via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Mon, 16 Aug 2021 21:00:44 +0000
All,
I am a bit stumped trying to get exampleCPP built for EPICS 7. Within the documentation, it says that the following need to be done.
make requires:
    A proper RELEASE.local is present one directory level above exampleCPP.
    Either ExampleRELEASE.local or MasterRELEASE.local is used.
ExampleRELEASE.local is used to build via an official EPICS 7 release.
MasterRELEASE.local is used to build via modules that have been cloned from github.
In either case the file chosen is copied to configure, renamed, and edited. For example:
cp ExampleRELEASE.local configure/RELEASE.local
gedit configure/RELEASE.local   // change EPICS7_DIR and possibly EPICS_BASE
The definition of EPICS7_DIR must be changed to the location where You installed and built a version of EPICS7.
I am not quite sure what this all entails. Some insight would be greatly appreciated.
Andy
Prev: Question about retrieve history data in archiver appliance lzfneu via Tech-talk
Next: phoebus display builder Vishnu Patel via Tech-talk
Prev: Re: RE: Question about retrieve history data in archiver appliance [email protected] via Tech-talk
