Subject: Re: Question about retrieve history data in archiver appliance
From: "Shankar, Murali via Tech-talk" <[email protected]>
Date: Tue, 17 Aug 2021 18:09:10 +0000
>> I intend to retrieve history data of some PV without running the IOC (offline), is it possible to implement that in archiver appliance.
Yes; this should be just fine.
>> I have no idea how to retrieve the history data of some PV without running the IOC
You should not have to do anything at all. Please check the use guide at https://slacmshankar.github.io/epicsarchiver_docs/userguide.html. For debugging, I usually find it simpler to start using something like curl to see what's going in. You can construct a retrieval URL and then use curl to retrieve the data using a .txt mime type.
Hope that helps.
Murali
Re: Question about retrieve history data in archiver appliance neu lzf via Tech-talk
Prev: phoebus display builder Vishnu Patel via Tech-talk
Next: RE: IOC PVA on mTCA CPU requires environment variables to be set Meeus Kris via Tech-talk
Prev: RE: Question about retrieve history data in archiver appliance Manoussakis, Adamandios via Tech-talk
Next: Re: Question about retrieve history data in archiver appliance neu lzf via Tech-talk
