Subject: Changing setter PVs with asyn and AreaDetector
From: Iain Marcuson via Tech-talk <[email protected]>
Date: Sun, 22 Aug 2021 19:32:36 +0000
I am working with a derivative of one of the QuadEM packages (namely NSLS_EM).  The IOC uses an asynPortDriver with separate setters and getters e.g. Integration time has setter `$(P)$(R)IntegrationTime` and getter `$(P)$(R)IntegrationTime_RBV`.  Since the electrometer state can change independently of the IOC, I want to reflect the state changes in the IOC.  I use a GUI in CSS BOY, and for the most part only display the setter PVs.  Is there a way to have the IOC update the setters, ideally through ASYN?  The initial value of Integration Time is reflected in the setter on IOC startup, but attempts at changing setters using setIntegerParam() only change the getter.  What might be causing this, and can I affect both setter and getter?
Thank you,
Iain Marcuson
Software Engineer, Sydor Technologies
585.278.1168 | www.SydorTechnologies.com
Skype: [email protected]
This message has been scanned for malware by Forcepoint. www.forcepoint.com
Re: Changing setter PVs with asyn and AreaDetector Mark Rivers via Tech-talk
Prev: Re: Configuring Phoebus alarm related display via a kafka message John Dobbins via Tech-talk
Next: RE: Question about retrieve history data in archiver appliance Manoussakis, Adamandios via Tech-talk
Next: Re: Changing setter PVs with asyn and AreaDetector Mark Rivers via Tech-talk
