You need to set the $(XSIZE) and $(YSIZE) macro variables in your st.cmd file to the maximum X andY size of your image. This is documented in EXAMPLE_commonPlugins.cmd.
Sent from my iPhone
On Aug 23, 2021, at 2:02 PM, Smith, William via Tech-talk <[email protected]> wrote:
I am using AD Stats plugin to determine the profile of a spot in an image. If I try and use a URL camera (Specifically an AXIS M114 camera) Then the profile is at most length 640 in the x dimension and 480 in the y, even if the image dimensions are greater than that. If I reduce the image size in the camera settings (not in area detector, but the camera itself) to an image size at or below 640x480, then the profile in x or y is that length.
I am able to plot the image from the StdArray plugin and I can see that it is the correct size. The image size is also reported correctly by $(P)cam1:ArraySizeX_RBV and $(P)cam1:ArraySizeY_RBV
Has anybody seen anything like this before? If I use this with the simDetector I have no problems, the profile length in each axis scales with the image size as expected.
Many thanks,
Will
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Jan Lüning (Sprecher), Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
- AD Stats with URL camera Profile problem Smith, William via Tech-talk
LIB_LIBS getting ignored Jones, Edward (CODAS&IT) via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
