Subject: LIB_LIBS getting ignored
From: "Jones, Edward \(CODAS&IT\) via Tech-talk" <[email protected]>
Date: Tue, 24 Aug 2021 12:24:36 +0000
Hello,
I’m trying to run a build where we’ve set INSTALL_LOCATION to /prefix and have found a buildable form with:
make EPICS_BASE=/prefix SUPPORT=/prefix
However, when I try to build my IOC itself at the final hurdle it doesn’t seem to link anything. This is what it tries to link:
/usr/bin/x86_64-w64-mingw32-g++ -o PICamApp.exe -static -L/ADPICam/lib/windows-x64-mingw -L/ADPICam/iocs/PICamIOC/lib/windows-x64-mingw       -m64    -static-libgcc -static-libstdc++         PICamApp_registerRecordDeviceDriver.o PICamAppMain.o    -lADPICam -lPicam  -lnetapi32    -lpsapi -lws2_32 -ladvapi32 -luser32 -lkernel32 -lwinmm -ldbghelp
Which lacks all the EPICS_BASE_IOC_LIBS, when I manually navigate to that directory and link it like so:
/usr/bin/x86_64-w64-mingw32-g++ -o PICamApp.exe -static -L/ADPICam/lib/windows-x64-mingw -L/ADPICam/iocs/PICamIOC/lib/windows-x64-mingw -L/prefix/lib/windows-x64-mingw      -m64    -static-libgcc -static-libstdc++         PICamApp_registerRecordDeviceDriver.o PICamAppMain.o    -lADPICam -lPicam  -lnetapi32    -lpsapi -lws2_32 -ladvapi32 -luser32 -lkernel32 -lwinmm -ldbghelp -ldbRecStd -ldbCore -lca -lCom -lasyn -lADBase -lca -lCom -lxml2 -lgdi32 -loleaut32 -lwsock32 -lws2_32 -lpsapi -ldbghelp -lversion -lzlib -lpv -ladvapi32 -luser32
This works. So it looks like the build method is missing all LIB_LIBS definitions. Could someone help to understand this? If you need I can share our work but must be privately done.
Ed
Re: LIB_LIBS getting ignored Johnson, Andrew N. via Tech-talk
Prev: Re: AD Stats with URL camera Profile problem Mark Rivers via Tech-talk
Next: EPICS support for Keithley 6517A unavailable, does anyone have it? Adam Szwandziak - STFC UKRI via Tech-talk
Next: Re: LIB_LIBS getting ignored Johnson, Andrew N. via Tech-talk
