Subject: RE: Unit testing IOCs and databases
From: Stainer Tom via Tech-talk <[email protected]>
To: Torsten Bögershausen <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 7 Sep 2021 11:36:04 +0000
Hi Torsten,
Thanks for the response, very helpful Torsten.
I also replied inline!
>> Essentially this boils down to 4 main questions:
>> - Given a db file what is the standard way to test logic and records inside it in an automated fashion?
> Not what I am aware of - the "standard way". Each record has it's own specific behaviour....
Fair enough. I was curious to know how people using EPICS write tests for logic they put in a record. For example, if you have a db file which implements a CALC, even if very simple (e.g. A+2B-C), but how do you ensure that this does what you think it does and doesn't change later? Coupled with the fact you may have 100+ PVs in a single db file that all depend on each other. I guess this is again at the integration test level....
>> - Using the V4 smart database, what is the standard way to mock the protocol i.e. PVA, to do more unit testing rather than integration testing?
>> - How do people mock hardware? Is this done by using the asynPortDriver interface?
> I am doing tests using both simulated and real hardware: Motion controllers and motors.
> Some tests need the simulator to simulate failures in HW...
> In any sense, there is a common motor driver, a model 3 driver.
> The simulator does the same things as the real HW, so we use the same driver in both cases.
Good to know.
>> - Has anyone tried using other libraries, such as google test, Catch2, doctest,… to do unit testing in EPICS? If so, how can I set this up with the EPICS build system?
> I am using pytest.
Great. I am using pytest for IOCs written in python, but a lot of the code is in C++ also.
> And the whole test-suite is rather a integration test, not a Unit test.
Yes indeed, we have many integration tests but we sometimes run into issues with broadcasts on the CI runner. Additionally, they can be quite slow, I was hoping to find ways to look at unit testing through use of mocks. In some cases however, we end up with too many mocked interfaces that at some point you question if this actually tests anything real in the end. Integration tests are more useful in these cases.
> If you, or anybody else, is interested, I can explain & show stuff in a video meeting.
Yes, I would find that very helpful!
Kind regards,
Tom
-----Original Message-----
Sent: Tuesday, September 7, 2021 1:07 PM
To: Stainer Tom <[email protected]>; [email protected]
Subject: Re: Unit testing IOCs and databases
Hej Tom,
some answers inline
From: Tech-talk <[email protected]> on behalf of Stainer Tom via Tech-talk <[email protected]>
Reply-To: Stainer Tom <[email protected]>
Date: Tuesday, 7 September 2021 at 11:13
Subject: Unit testing IOCs and databases
Hello EPICS community,
I have a question, that is quite broad in its nature (I know these don’t go down well here but thought I’d try anyway), regarding testing in EPICS.
Specifically I am interested in how people using EPICS generally test their applications and the logic in IOCs, at a unit testing level.
I am not talking about testing epics-base, of course I trust that your tests provide good coverage ☺. What I am interested in is how can I test logic that is in an IOC (db file or via smart database).
I am using pytest.
Kind regards,
Tom
RE: Unit testing IOCs and databases Freddie Akeroyd - STFC UKRI via Tech-talk
Unit testing IOCs and databases Stainer Tom via Tech-talk
Re: Unit testing IOCs and databases Torsten Bögershausen via Tech-talk
Prev: Re: Unit testing IOCs and databases Simon Rose via Tech-talk
Next: RE: Unit testing IOCs and databases Freddie Akeroyd - STFC UKRI via Tech-talk
Prev: Re: Unit testing IOCs and databases Torsten Bögershausen via Tech-talk
