Hi Kay,
As for building, the older Eclipse-based setup can be very difficult.
You might want to try the newer source base,https://github.com/ControlSystemStudio/phoebus
I will try to built Archive Engine, Alarm Server and SQL schemas from
source base of Phoebus. But our client PCs is running CSS 4.5.9. If I do
it, could there be conflict between Database Server and Clients? Or
else, should I install Phoebus to clients? So, I'm wondering that if we
jump to Phoebus on clients, could there be unexpected problems on opis?
They are case-sensitive, so I assume it's a copy/paste error?
Yes, I wrote the command by hand. Sorry for this.
And I found a written documentation about Alarm System Toolkit (with
Tomcat, JMS, CSS and etc. tools ) by you. (I attached it that named
BEAST.doc) Is there an any documentation for built Alarm Server and/or
Archive Engine with Apache Kafka, JMS, Phoebus and etc. tools? (I just
read that these modern tools are used in tech-talks while I try to
search source code of CSS 4.5.9.)
Hasan Sansar
BEAST.doc
Description: MS-Word document
- Re: [EXTERNAL] Alarm Server and archiveEngine Kasemir, Kay via Tech-talk
- Alarm Server and archiveEngine Hasan SANSAR via Tech-talk
RE: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Freddie Akeroyd - STFC UKRI via Tech-talk
Re: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Veseli, Sinisa via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
