Subject: Re: [EXTERNAL] Alarm Server and archiveEngine
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: Hasan SANSAR <[email protected]>
Date: Mon, 13 Sep 2021 12:19:52 +0000
>source base of Phoebus. But our client PCs is running CSS 4.5.9. If I do
it, could there be conflict between Database Server and Clients? Or
else, should I install Phoebus to clients? So, I'm wondering that if we
jump to Phoebus on clients, could there be unexpected problems on opis?
The original Eclipse-based CS-Studio and the Phoebus version are 100% compatible regarding archived data.
Same RDB schema.
For displays, there is also a high degree of compatibility, see https://github.com/ControlSystemStudio/phoebus/wiki/Display-Builder-Compatibility
> Is there an any documentation for built Alarm Server and/or
Archive Engine with Apache Kafka, JMS, Phoebus and etc. tools?
For alarms, you can export/import the configuration, but the tools are not compatible at runtime because we moved from RDB+JMS to Kafka.
-Kay
Re: [EXTERNAL] Alarm Server and archiveEngine Hasan SANSAR via Tech-talk
Re: [EXTERNAL] Alarm Server and archiveEngine Kasemir, Kay via Tech-talk
Prev: RE: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Mark Rivers via Tech-talk
Next: Re: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Veseli, Sinisa via Tech-talk
Prev: Re: [EXTERNAL] Alarm Server and archiveEngine Hasan SANSAR via Tech-talk
Next: Re: [EXTERNAL] Alarm Server and archiveEngine Hasan SANSAR via Tech-talk
