Subject: Re: SynApps sscan record: timestamp issue for BUSY DATA and EXSC fields; causing problem archiving with Phoebus Archive engine
From: "Mooney, Tim M. via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, Kuldeep Joshi <[email protected]>
Date: Tue, 14 Sep 2021 13:11:56 +0000
Hi Kuldeep,
This doesn't look like a normal scan to me.  BUSY should go to 1 promptly after EXSC is set to 1.  I would try monitoring SMSG to verify that the scan is behaving normally - not flailing with a disconnected positioner PV, for example.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: Tech-talk <[email protected]> on behalf of Kuldeep Joshi via Tech-talk <[email protected]>
Sent: Tuesday, September 14, 2021 5:20 AM
To: [email protected] <[email protected]>
Subject: SynApps sscan record: timestamp issue for BUSY DATA and EXSC fields; causing problem archiving with Phoebus Archive engine
Hello
I am getting the following output from camonitor for BUSY DATA and EXSC field of sscan record. I see in camonitor the timestamp for the sscan BUSY field is same for busy state and not busy.
iocA:scan1.EXSC               2021-09-14 14:10:10.180717 1
iocA:scan1.DATA               2021-09-14 14:24:49.126318 0
iocA:scan1.BUSY               2021-09-14 14:24:49.126318 1
iocA:scan1.EXSC               2021-09-14 14:24:49.126318 0
iocA:scan1.DATA               2021-09-14 14:24:49.126318 1
iocA:scan1.BUSY               2021-09-14 14:24:49.126318 0
iocA:scan1.EXSC               2021-09-14 14:24:49.126318 1
iocA:scan1.DATA               2021-09-14 14:30:58.778731 0
iocA:scan1.BUSY               2021-09-14 14:30:58.778731 1
iocA:scan1.EXSC               2021-09-14 14:30:58.778731 0
iocA:scan1.DATA               2021-09-14 14:30:58.778731 1
iocA:scan1.BUSY               2021-09-14 14:30:58.778731 0
I was thinking of archiving the BUSY field to indicate the start and end of scan. Here the archive engine of phoebus stores only the initial event Busy =1. This also causes the BUSY to be seen a spike in the databrowser.
The postgresql table listing for BUSY is given below
         56 | 2021-09-14 14:24:49.126318 | 126317989 |           5 |         8 |       1 |           |             |          |
         56 | 2021-09-14 14:30:01.659215 | 659214550 |           4 |        10 |         |           | Archive_Off |          |
         56 | 2021-09-14 14:30:01.759215 | 759215000 |           5 |         8 |       0 |           |             |          |
         56 | 2021-09-14 14:30:58.778731 | 778731080 |           5 |         8 |       1 |           |             |          |
If I have to extract the timeperiod during which the scan was active, I may have to use additional records to monitor the BUSY field and archive it.
Anyway in which I can achieve it elegantly
Kuldeep
Re: SynApps sscan record: timestamp issue for BUSY DATA and EXSC fields; causing problem archiving with Phoebus Archive engine Kuldeep Joshi via Tech-talk
Prev: Re: SynApps sscan record: timestamp issue for BUSY DATA and EXSC fields; causing problem archiving with Phoebus Archive engine Ralph Lange via Tech-talk
Next: Re: Download prblem for sequenzer Ben Franksen via Tech-talk
Next: Re: SynApps sscan record: timestamp issue for BUSY DATA and EXSC fields; causing problem archiving with Phoebus Archive engine Kuldeep Joshi via Tech-talk
