Subject: NDPluginPva - PV not appearing on network
From: "Warrick, Edmund \(DLSLtd, RAL, LSCI\) via Tech-talk" <[email protected]>
Date: Tue, 14 Sep 2021 16:04:20 +0000
I’m trying to use the NDPluginPva plugin from ADCore to support a live viewer application for one of our beamline detectors. On one of my detectors, I seem to see the EPICS v4 PV consistently fail to appear on the network.
Using ADCore 3-8, PVAccess 7-0-0, on RHEL7.9
Relevant parts of my ioc startup script:
# NDPvaConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, pvName, maxBuffers, maxMemory, priority, stackSize)
NDPvaConfigure("EXCBR.pva", 16, 0, "EXCBR.CAM", 0, BL14I-EA-EXCBR-02:PVA:ARRAY, 0, 0, 0, 0)
startPVAServer
No error messages produced, and no alarm state shown by any of the v3 PVs in the plugin – but a pvget to the PV returned by PvName_RBV consistently times out. pvlist shows the detector server as hosting a pvaserver instance, but pvlist <host ip>:<port> to list the hosted PVs also times out.
I suspect some sort of race condition – by stripping back the IOC, removing everything but the PVA plugin and a simdetector instance, I can get it to successfully start serving the PV on startup some of the time, although sometimes it still fails to appear. When using the full detector driver IOC, it always fails.
Other ADCore IOCs on the same network using NDPluginPva respond to pvget requests as expected, and running up one of these IOCs temporarily on the same detector server also results in its PVA PV appearing.
I’d appreciate any assistance you can suggest with debugging this. I’m happy to provide any further diagnostic information that may help.
Ed Warrick
Senior Software Systems Engineer
Diamond Light Source
RE: NDPluginPva - PV not appearing on network Mark Rivers via Tech-talk
Prev: Re: Download prblem for sequenzer Ben Franksen via Tech-talk
Next: RE: NDPluginPva - PV not appearing on network Mark Rivers via Tech-talk
Prev: RE: SynApps sscan record: timestamp issue for BUSY DATA and EXSC fields; causing problem archiving with Phoebus Archive engine Mark Rivers via Tech-talk
