Subject: Re: modbusTCP
To: liuxiaomin <[email protected]>
Date: Wed, 22 Sep 2021 12:35:02 +0000
You have 2 error messages:
> drvStreamInit: Warning! STREAM_PROTOCOL_PATH not set. Defaults to "."
That error message is normal and can be ignored if you are not using Stream device in your IOC.
> TEST:CAT1:IN1 devAsynInt32::initCommon connectDevice failed asynManager:connectDevice port CAT_AI1R not found
This error is not normal, and means you probably have an error in your st.cmd file.  Please send the complete output when the IOC boots, not just the error message.
From: Tech-talk <[email protected]> on behalf of liuxiaomin via Tech-talk <[email protected]>
Sent: Wednesday, September 22, 2021 1:10 AM
To: Smith, Martin via Tech-talk
Subject: modbusTCP
  I am trying to use modbus on debian system to control device,
When I execute the st.cmd file,it shows the following error:
How can I solve this problem?
Xiaomin
从 Windows 版邮件<https://go.microsoft.com/fwlink/?LinkId=550986>发送
modbusTCP liuxiaomin via Tech-talk
Prev: Re: crash in CAS-event (high load?) Till Straumann via Tech-talk
Next: Re: modbus TCP Mark Rivers via Tech-talk
Prev: modbusTCP liuxiaomin via Tech-talk
Next: modbus TCP liuxiaomin via Tech-talk
