Then, $ caget TEST:IN1 CA.Client.Exception…............................................ Warning: “Identical process variable names on multiple servers” Context: “Channel: “TEST:IN1”, Connecting to: 192.168.1.160:41299, Ignored: 192.168.1.160:5064” Source File: ../cac.cpp line 1320 Current Time: Fri Sep 24 2021 18:16:53.789456666 …............................................................... TEST:IN1 0
Careful.
means that you are running two IOCs on the same host that contain the same record. Please double-check that you killed all running IOCs before starting a new instance.
Cheers, ~Ralph
- modbus TCP liuxiaomin via Tech-talk
- Re: modbus TCP Mark Rivers via Tech-talk
- 回复: modbus TCP liuxiaomin via Tech-talk
Rec Proc Monitor no longer in EPICs 7 record reference documentation. Wang, Andrew via Tech-talk
<2021>
2025
2026
Ava in caQtDM Mezger Anton Christian (PSI) via Tech-talk
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
