Subject: 回复: modbus TCP
Date: Fri, 24 Sep 2021 18:50:36 +0800
Hi Mark,
I am sorry to have sent you two emails,the first one can be ignored.
Thank you for your answer,  My type of device  at that IP address is MPDU.
I changed the IP address.( 192.168.1.163:8055) . And the complete output is as follows:
#!../../bin/linux-x86_64/sinModbus
< envPaths
epicsEnvSet("IOC","iocsinModbus")
epicsEnvSet("TOP","/home/iocusr/sinModbus")
epicsEnvSet("MODULES","/opt/epics/base/../modules")
epicsEnvSet("AUTOSAVE","/opt/epics/base/../modules/autosave-R5-7-1")
epicsEnvSet("ASYN","/opt/epics/base/../modules/asyn-R4-41")
epicsEnvSet("BUSY","/opt/epics/base/../modules/busy-1-6-1")
epicsEnvSet("CALC","/opt/epics/base/../modules/calc-R3-7-4")
epicsEnvSet("CAPUTLOG","/opt/epics/base/../modules/caPutLog-3-5")
epicsEnvSet("IOCSTATS","/opt/epics/base/../modules/iocStats-3-1-16")
epicsEnvSet("MODBUS","/opt/epics/base/../modules/modbus-R3-2")
epicsEnvSet("NETDEV","/opt/epics/base/../modules/netDev-1-0-6")
epicsEnvSet("PC-MONITOR","/opt/epics/base/../modules/PC-MONITOR1-0-2")
epicsEnvSet("PROCSERVCONTROL","/opt/epics/base/../modules/procServControl-1-9")
epicsEnvSet("S7NODAVE","/opt/epics/base/../modules/s7nodave-2-1-3")
epicsEnvSet("S7PLC","/opt/epics/base/../modules/s7plc")
epicsEnvSet("SSCAN","/opt/epics/base/../modules/sscan-2-10")
epicsEnvSet("STREAM","/opt/epics/base/../modules/StreamDevice-2-8-9")
epicsEnvSet("SNCSEQ","/opt/epics/base/../modules/seq-2-2-6")
epicsEnvSet("EPICS_BASE","/opt/epics/base")
epicsEnvSet("EPICS_CA_SERVER_PORT", 5064)
#epicsEnvSet("IOCNAME","sinModbus")
dbLoadDatabase "../../dbd/sinModbus.dbd"
sinModbus_registerRecordDeviceDriver pdbbase
#asynReport(10,"CAT1")
# Configure IP port
drvAsynIPPortConfigure("CAT1","192.168.1.163:8055",0,0,1)
# Configure modbus
modbusInterposeConfig("CAT1",0,2000,0)
drvModbusAsynConfigure("AI1R","CAT1",0,3,0010,2,0,100,"CAT")
#cd "${TOP}/iocBoot/${IOC}"
dbLoadRecords "../../db/dbpdu.db", "DEVNAME=TEST"
iocInit
Starting iocInit
## EPICS R7.0.5
## Rev. 2021-09-13T15:44+0800
drvStreamInit: Warning! STREAM_PROTOCOL_PATH not set. Defaults to "."
sevr=info s7plcInit: no stations configured
dbl
TEST:IN1
epics> 2021/09/24 18:14:37.388 drvModbusAsyn::doModbusIO port AI1R error calling writeRead, error=192.168.1.163:8055 timeout: Resource temporarily unavailable, nwrite=6/6, nread=0
After I  typing asynReport 1,the complete output is as follows:
epics> asynReport 1
CAT1 multiDevice:No canBlock:Yes autoConnect:Yes
enabled:Yes connected:Yes numberConnects 1
nDevices 0 nQueued 0 blocked:No
asynManagerLock:No synchronousLock:No
exceptionActive:No exceptionUsers 0 exceptionNotifys 0
traceMask:0x1 traceIOMask:0x0 traceInfoMask:0x1
Port 192.168.1.163:8055: Connected
AI1R multiDevice:Yes canBlock:Yes autoConnect:Yes
nDevices 1 nQueued 0 blocked:No
addr 0 autoConnect Yes enabled Yes connected Yes exceptionActive No
        exceptionActive No exceptionUsers 0 exceptionNotifys 0
        blocked No
modbus port: AI1R
initialized:        true
asynOctet server:   CAT1
modbusSlave:        0
modbusFunction:     3
modbusStartAddress: 010
modbusLength:       02
absoluteAddressing: false
dataType:           0 (INT16)
plcType:
I/O errors:         9
Read OK:            0
Write OK:           0
pollDelay:          0.100000
Time for last I/O   0 msec
Max. I/O time:      0 msec
Time per hist. bin: 1 msec
Port: AI1R
  Timestamp: <undefined>
  Input EOS[0]:
  Output EOS[0]:
Parameter list 0
Number of parameters is: 12
Parameter 0 type=asynInt32, name=MODBUS_DATA, value is undefined
Parameter 1 type=asynInt32, name=MODBUS_READ, value is undefined
Parameter 2 type=asynUInt32Digital, name=ENABLE_HISTOGRAM, value is undefined
Parameter 3 type=asynInt32, name=READ_HISTOGRAM, value is undefined
Parameter 4 type=asynInt32, name=HISTOGRAM_BIN_TIME, value is undefined
Parameter 5 type=asynInt32Array, name=HISTOGRAM_TIME_AXIS, value is undefined
Parameter 6 type=asynFloat64, name=POLL_DELAY, value is undefined
Parameter 7 type=asynInt32, name=READ_OK, value=0, status=0
Parameter 8 type=asynInt32, name=WRITE_OK, value=0, status=0
Parameter 9 type=asynInt32, name=IO_ERRORS, value=9, status=0
Parameter 10 type=asynInt32, name=LAST_IO_TIME, value=0, status=0
Parameter 11 type=asynInt32, name=MAX_IO_TIME, value=0, status=0
epics>
Then,
$ caget TEST:IN1
CA.Client.Exception............................................
Warning: Identical process variable names on multiple servers
Context: Channel: TEST:IN1, Connecting to: 192.168.1.160:41299, Ignored: 192.168.1.160:5064
Source File: ../cac.cpp line 1320
Current Time: Fri Sep 24 2021 18:16:53.789456666
TEST:IN1                       0
Finally, I found  the result read value was wrong.
Windows 邮件发送
发件人: Mark Rivers
发送时间: 2021922 20:51
收件人: liuxiaomin
抄送: [email protected]
主题: Re: modbus TCP
Sorry I did not see your second message before I answered your first one.
The st.cmd looks OK to me.  Please send the complete output when the IOC boots.
From: Tech-talk <[email protected]> on behalf of liuxiaomin via Tech-talk <[email protected]>
Sent: Wednesday, September 22, 2021 1:45 AM
To: [email protected]
Subject: modbus TCP
  I am trying to use modbus on debian system to control device,
The st.cmd files is as follows:
drvAsynIPPortConfigure("CAT1","192.168.1.163:502",0,0,1)
drvModbusAsynConfigure("CAT_AI1R","CAT1",0,3,0008,2,0,100, "CAT")
The db files is as follows:
record(ai, "$(DEVNAME):IN1") {
    field(DTYP,"asynInt32")
    field(INP,"@asynMask(CAT_AI1R 0 16)INT16")
    field(PREC,"1")
    field(SCAN,"I/O Intr")
When I execute the st.cmd file,it shows the following error:
TEST:CAT1:IN1 devAsynInt32::initCommon connectDevice failed asynManager:connectDevice port CAT_AI1R not found
How can I solve this problem?
Xiaomin
Windows 版邮件<https://go.microsoft.com/fwlink/?LinkId=550986>发送
Re: modbus TCP Mark Rivers via Tech-talk
Re: modbus TCP Ralph Lange via Tech-talk
modbus TCP liuxiaomin via Tech-talk
Prev: Re: EPICS 7-0-6 Release Notes Link error Timo Korhonen via Tech-talk
Next: Re: modbus TCP Mark Rivers via Tech-talk
Prev: Re: modbus TCP Mark Rivers via Tech-talk
