1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: channel and pv deadband
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Mezger Anton Christian (PSI)" <[email protected]>
Date: Fri, 1 Oct 2021 12:08:20 +0000
Can you give a reproducible example?
I tried this record with `softIocPVA` from EPICS base 7.0.6:
record(ai, "number")
  field(INP,  "10")
  field(MDEL, "2")
  field(PINI, "YES")
Both `camonitor number` and `pvmonitor number` start out by displaying the current number, and from then on they reflect changes beyond the MDEL.
So as was the case before EPICS 7, the monitor starts with an initial update, both for Channel Access and PV Access.
-Kay
From: Tech-talk <[email protected]> on behalf of Mezger Anton Christian (PSI) via Tech-talk <[email protected]>
Sent: Friday, October 1, 2021 7:24 AM
To: [email protected] <[email protected]>
Subject: [EXTERNAL] channel and pv deadband
When in epics7 a channel or pv is monitored with a deadband  (perhaps also in 3.15), then a value will only be given when the value exceeds the deadband. This is the expected behaviour. However in case of a display manager, no value will be displayed when monitoring values until the deadband is exceeded. This seems to me a rather special behaviour for existing display managers that rely on monitoring the values.
Perhaps I am wrong, but perhaps a first value should be send?
channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
Prev: High Voltage PS with RS-232 serial port Hasan SANSAR via Tech-talk
Next: Re: channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
