Subject: Re: channel and pv deadband
From: "Mezger Anton Christian \(PSI\) via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Kasemir, Kay" <[email protected]>
Date: Fri, 1 Oct 2021 13:14:23 +0000
The problem is with the deadband specified as filter with a channel or pv. My example:
record(ao,"ACM:TEST:AO") {
    field(DESC,"analog output record")
    field(SCAN,"Passive")
    field(PINI,"NO")
    field(PHAS,"0")
    field(EVNT,"0")
    field(DTYP,"Soft Channel")
    field(DISV,"1")
    field(SDIS,"0.000000000000000e+00")
    field(DISS,"NO_ALARM")
    field(PRIO,"LOW")
    field(FLNK,"0.000000000000000e+00")
    field(OUT,"0.000000000000000e+00")
    field(OROC,"0.0000000e+00")
    field(DOL,"0.000000000000000e+00")
    field(OMSL,"supervisory")
    field(OIF,"Full")
    field(PREC,"5")
    field(LINR,"NO CONVERSION")
    field(EGUF,"0.0000000e+00")
    field(EGUL,"0.0000000e+00")
    field(EGU,"V")
    field(DRVH,"1000.0")
    field(DRVL,"-1000.0")
    field(HOPR,"900.0")
    field(LOPR,"0.0")
    field(AOFF,"0.0000000e+00")
    field(ASLO,"0.0000000e+00")
    field(HIHI,"900.0")
    field(LOLO,"0.0")
    field(HIGH,"450.0")
    field(LOW,"0.0")
    field(HHSV,"MAJOR")
    field(LLSV,"NO_ALARM")
    field(HSV,"MINOR")
    field(LSV,"NO_ALARM")
    field(HYST,"0.000000000000000e+00")
    field(ADEL,"0.000000000000000e+00")
    field(MDEL,"0.000000000000000e+00")
    field(SIOL,"0.000000000000000e+00")
    field(SIML,"0.000000000000000e+00")
    field(SIMS,"NO_ALARM")
    field(IVOA,"Continue normally")
    field(IVOV,"0.000000000000000e+00")
and withcamonitor ACM:TEST:AO.{"dbnd":{"abs":1.5}}
I only get update when I put a value outside the deadband
Anton
Sent: Friday, October 1, 2021 2:08:20 PM
To: [email protected]; Mezger Anton Christian (PSI)
Can you give a reproducible example?
I tried this record with `softIocPVA` from EPICS base 7.0.6:
record(ai, "number")
  field(INP,  "10")
  field(MDEL, "2")
  field(PINI, "YES")
Both `camonitor number` and `pvmonitor number` start out by displaying the current number, and from then on they reflect changes beyond the MDEL.
So as was the case before EPICS 7, the monitor starts with an initial update, both for Channel Access and PV Access.
-Kay
From: Tech-talk <[email protected]> on behalf of Mezger Anton Christian (PSI) via Tech-talk <[email protected]>
Sent: Friday, October 1, 2021 7:24 AM
To: [email protected] <[email protected]>
Subject: [EXTERNAL] channel and pv deadband
When in epics7 a channel or pv is monitored with a deadband  (perhaps also in 3.15), then a value will only be given when the value exceeds the deadband. This is the expected behaviour. However in case of a display manager, no value will be displayed when monitoring values until the deadband is exceeded. This seems to me a rather special behaviour for existing display managers that rely on monitoring the values.
Perhaps I am wrong, but perhaps a first value should be send?
Re: channel and pv deadband Johnson, Andrew N. via Tech-talk
channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
Re: channel and pv deadband Kasemir, Kay via Tech-talk
Prev: Re: channel and pv deadband Kasemir, Kay via Tech-talk
Next: Re: High Voltage PS with RS-232 serial port Eric Norum via Tech-talk
Next: Re: channel and pv deadband Johnson, Andrew N. via Tech-talk
