1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: channel and pv deadband
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Mezger Anton Christian (PSI)" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Sat, 2 Oct 2021 22:27:02 +0000
Hi Anton,
On Oct 1, 2021, at 8:14 AM, Mezger Anton Christian (PSI) via Tech-talk <[email protected]> wrote:
The problem is with the deadband specified as filter with a channel or pv. My example:
record(ao,"ACM:TEST:AO") {
    field(DTYP,"Soft Channel")
    field(MDEL,"0.000000000000000e+00")
and withcamonitor ACM:TEST:AO.{"dbnd":{"abs":1.5}}
I only get update when I put a value outside the deadband
I can’t seem to replicate your issue. I’m using this database:
woz$ cat ~/db/analog.db
record(ai, "ai") {}
record(ao, "ao") {}
Here’s me starting the soft IOC and writing to the records:
woz$ softIoc -d ~/db/analog.db
Starting iocInit
## EPICS R7.0.6.1-DEV
## Rev. R7.0.6-23-g21e7e4ddfbfbcf8ca5c6-dirty
epics> dbpf ai 10
DBF_DOUBLE:         10
epics> dbpf ai 0
DBF_DOUBLE:         0
epics> dbpf ai 1
DBF_DOUBLE:         1
epics> dbpf ai 1.49
DBF_DOUBLE:         1.49
epics> dbpf ai 1.5
DBF_DOUBLE:         1.5
epics> dbpf ai 1.501
DBF_DOUBLE:         1.501
epics> dbpf ao 1.5
DBF_DOUBLE:         1.5
epics> dbpf ao 1.501
DBF_DOUBLE:         1.501
epics> dbpf ao 1
DBF_DOUBLE:         1
epics> dbpf ao 0.1
DBF_DOUBLE:         0.1
epics> dbpf ao 0
DBF_DOUBLE:         0
and here’s what my camonitor output looked like. I started it immediately after the softIoc, before the first dbpf command above:
woz$ camonitor 'ai.{dbnd:{abs:1.5}}' 'ao.{dbnd:{abs:1.5}}'
ai.{dbnd:{abs:1.5}}            <undefined> 0 UDF INVALID
ao.{dbnd:{abs:1.5}}            <undefined> 0 UDF INVALID
ai.{dbnd:{abs:1.5}}            2021-10-02 17:08:32.684729 10
ai.{dbnd:{abs:1.5}}            2021-10-02 17:08:39.867667 0
ai.{dbnd:{abs:1.5}}            2021-10-02 17:09:05.595295 1.501
ao.{dbnd:{abs:1.5}}            2021-10-02 17:09:32.741622 1.501
ao.{dbnd:{abs:1.5}}            2021-10-02 17:10:02.573699 0
The first two lines that show the undefined timestamp and UDF/Invalid alarm give the initial channel values as zero, then after testing with 10 and 0 there were no monitors posted until the value went over the deadband.
If you’re seeing something different, can you post your complete output from camonitor?
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
Re: channel and pv deadband Kasemir, Kay via Tech-talk
Prev: Backing up the ArchiverStores STS MTS LTS Epic Archiver Appliance Manoussakis, Adamandios via Tech-talk
Next: Re: channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
