Subject: Backing up the ArchiverStores STS MTS LTS Epic Archiver Appliance
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Sat, 2 Oct 2021 00:28:30 +0000
Hey All,
I couldn’t find a clear explanation on backing up the STS MTS LTS from the archiver appliance and also clearing out the archiverstores after saving them off.  Can I just copy these folders with the protobuf files in it and save them off, if needed I would drop them back into their respective directories if I wanted to use them again?  Am I able to just delete the ArchiverStores after STS MTS LTS have been saved off and they will get remade or would I need to go about this differently?  I tried to look through some of the scripting in the bpl documentation but couldn’t find what I was looking for.  I did find some documentation on saving off configuration of the mysql database, are the config parameters mostly just the PV names and settings for each of the PVs while the data is stored in the protobuff files?
Adam
Prev: Re: High Voltage PS with RS-232 serial port Maren Purves via Tech-talk
Next: Re: channel and pv deadband Johnson, Andrew N. via Tech-talk
Next: Fw: Backing up the ArchiverStores STS MTS LTS Epic Archiver Appliance Wilson, Andy (DLSLtd, RAL, LSCI) via Tech-talk
