1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: channel and pv deadband
From: "Mezger Anton Christian \(PSI\) via Tech-talk" <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Sun, 3 Oct 2021 08:26:25 +0000
Hi Andrew,
me again. Epics4 works now for me, everything solved with some hints of michael.
The problem of camonitor with specifying a deadband:
I got from camonitor the following. The multiple servers could be a problem, but I do not know how to get rid of it in my centos with virtualbox.
EPICS_CA_ADDR_LIST=localhost has been specified
I get after starting the softioc
 camonitor ACM:TEST:AO.{"dbnd":{"abs":1.5}}
ACM:TEST:AO.{dbnd:{abs:1.5}}   <undefined> 0 UDF INVALID
CA.Client.Exception...............................................
    Warning: "Identical process variable names on multiple servers"
    Context: "Channel: "ACM:TEST:AO.{dbnd:{abs:1.5}}", Connecting to: 10.0.2.15:5064, Ignored: osboxes:5064"
    Source File: ../cac.cpp line 1320
    Current Time: Sun Oct 03 2021 04:22:15.964251792
    Context: "Channel: "ACM:TEST:AO.{dbnd:{abs:1.5}}", Connecting to: 10.0.2.15:5064, Ignored: localhost:5064"
    Current Time: Sun Oct 03 2021 04:22:15.964387808
when I do caput ACM:TEST:AO 1 I do not get a monitor
when I do caput ACM:TEST:AO 2 I get
ACM:TEST:AO.{dbnd:{abs:1.5}}   2021-10-03 04:24:03.931949 2
If it works for you, then I wonder what is going on.
many thanks
Sent: Sunday, October 3, 2021 12:27:02 AM
To: Mezger Anton Christian (PSI)
Cc: EPICS tech-talk
Hi Anton,
On Oct 1, 2021, at 8:14 AM, Mezger Anton Christian (PSI) via Tech-talk <[email protected]> wrote:
The problem is with the deadband specified as filter with a channel or pv. My example:
record(ao,"ACM:TEST:AO") {
    field(DTYP,"Soft Channel")
    field(MDEL,"0.000000000000000e+00")
and withcamonitor ACM:TEST:AO.{"dbnd":{"abs":1.5}}
I only get update when I put a value outside the deadband
I can’t seem to replicate your issue. I’m using this database:
woz$ cat ~/db/analog.db
record(ai, "ai") {}
record(ao, "ao") {}
Here’s me starting the soft IOC and writing to the records:
woz$ softIoc -d ~/db/analog.db
Starting iocInit
## EPICS R7.0.6.1-DEV
## Rev. R7.0.6-23-g21e7e4ddfbfbcf8ca5c6-dirty
epics> dbpf ai 10
DBF_DOUBLE:         10
epics> dbpf ai 0
DBF_DOUBLE:         0
epics> dbpf ai 1
DBF_DOUBLE:         1
epics> dbpf ai 1.49
DBF_DOUBLE:         1.49
epics> dbpf ai 1.5
DBF_DOUBLE:         1.5
epics> dbpf ai 1.501
DBF_DOUBLE:         1.501
epics> dbpf ao 1.5
DBF_DOUBLE:         1.5
epics> dbpf ao 1.501
DBF_DOUBLE:         1.501
epics> dbpf ao 1
DBF_DOUBLE:         1
epics> dbpf ao 0.1
DBF_DOUBLE:         0.1
epics> dbpf ao 0
DBF_DOUBLE:         0
and here’s what my camonitor output looked like. I started it immediately after the softIoc, before the first dbpf command above:
woz$ camonitor 'ai.{dbnd:{abs:1.5}}' 'ao.{dbnd:{abs:1.5}}'
ai.{dbnd:{abs:1.5}}            <undefined> 0 UDF INVALID
ao.{dbnd:{abs:1.5}}            <undefined> 0 UDF INVALID
ai.{dbnd:{abs:1.5}}            2021-10-02 17:08:32.684729 10
ai.{dbnd:{abs:1.5}}            2021-10-02 17:08:39.867667 0
ai.{dbnd:{abs:1.5}}            2021-10-02 17:09:05.595295 1.501
ao.{dbnd:{abs:1.5}}            2021-10-02 17:09:32.741622 1.501
ao.{dbnd:{abs:1.5}}            2021-10-02 17:10:02.573699 0
The first two lines that show the undefined timestamp and UDF/Invalid alarm give the initial channel values as zero, then after testing with 10 and 0 there were no monitors posted until the value went over the deadband.
If you’re seeing something different, can you post your complete output from camonitor?
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
Re: channel and pv deadband Kasemir, Kay via Tech-talk
Re: channel and pv deadband Johnson, Andrew N. via Tech-talk
Prev: Re: channel and pv deadband Johnson, Andrew N. via Tech-talk
Next: Re: channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
