Subject: Re: channel and pv deadband
From: "Mezger Anton Christian \(PSI\) via Tech-talk" <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Sun, 3 Oct 2021 09:28:10 +0000
Hi Andrew,
after analyzing more, the problem lies between the fact that  between an
 <undefined> 0 UDF INVALID and then real values the deadband must be exceeded before a monitor turns up.
one gets the following after ioc startup.
ACM:TEST:AO.{dbnd:{abs:1.5}}   <undefined> 0 UDF INVALID
one gets nothing after writing  the value 0 to ACM:TEST:A0
one gets nothing after writing  the value 1 to ACM:TEST:A0
one gets a monitor when writing the value 2 to ACM:TEST:A0
ACM:TEST:AO.{dbnd:{abs:1.5}}   2021-10-03 05:17:38.406470 2
What does that mean for a display manager? Should not the real value 0 then be given later from the monitor when 0 is written?
best regards
Anton
Sent: Sunday, October 3, 2021 10:26:25 AM
To: Johnson, Andrew N.
Cc: EPICS tech-talk
Hi Andrew,
me again. Epics4 works now for me, everything solved with some hints of michael.
The problem of camonitor with specifying a deadband:
I got from camonitor the following. The multiple servers could be a problem, but I do not know how to get rid of it in my centos with virtualbox.
EPICS_CA_ADDR_LIST=localhost has been specified
I get after starting the softioc
 camonitor ACM:TEST:AO.{"dbnd":{"abs":1.5}}
CA.Client.Exception...............................................
    Warning: "Identical process variable names on multiple servers"
    Context: "Channel: "ACM:TEST:AO.{dbnd:{abs:1.5}}", Connecting to: 10.0.2.15:5064, Ignored: osboxes:5064"
    Source File: ../cac.cpp line 1320
    Current Time: Sun Oct 03 2021 04:22:15.964251792
    Context: "Channel: "ACM:TEST:AO.{dbnd:{abs:1.5}}", Connecting to: 10.0.2.15:5064, Ignored: localhost:5064"
    Current Time: Sun Oct 03 2021 04:22:15.964387808
when I do caput ACM:TEST:AO 1 I do not get a monitor
when I do caput ACM:TEST:AO 2 I get
ACM:TEST:AO.{dbnd:{abs:1.5}}   2021-10-03 04:24:03.931949 2
If it works for you, then I wonder what is going on.
many thanks
Sent: Sunday, October 3, 2021 12:27:02 AM
To: Mezger Anton Christian (PSI)
Cc: EPICS tech-talk
Hi Anton,
On Oct 1, 2021, at 8:14 AM, Mezger Anton Christian (PSI) via Tech-talk <[email protected]> wrote:
The problem is with the deadband specified as filter with a channel or pv. My example:
record(ao,"ACM:TEST:AO") {
    field(DTYP,"Soft Channel")
    field(MDEL,"0.000000000000000e+00")
and withcamonitor ACM:TEST:AO.{"dbnd":{"abs":1.5}}
I only get update when I put a value outside the deadband
I can’t seem to replicate your issue. I’m using this database:
woz$ cat ~/db/analog.db
record(ai, "ai") {}
record(ao, "ao") {}
Here’s me starting the soft IOC and writing to the records:
woz$ softIoc -d ~/db/analog.db
Starting iocInit
## EPICS R7.0.6.1-DEV
## Rev. R7.0.6-23-g21e7e4ddfbfbcf8ca5c6-dirty
epics> dbpf ai 10
DBF_DOUBLE:         10
epics> dbpf ai 0
DBF_DOUBLE:         0
epics> dbpf ai 1
DBF_DOUBLE:         1
epics> dbpf ai 1.49
DBF_DOUBLE:         1.49
epics> dbpf ai 1.5
DBF_DOUBLE:         1.5
epics> dbpf ai 1.501
DBF_DOUBLE:         1.501
epics> dbpf ao 1.5
DBF_DOUBLE:         1.5
epics> dbpf ao 1.501
DBF_DOUBLE:         1.501
epics> dbpf ao 1
DBF_DOUBLE:         1
epics> dbpf ao 0.1
DBF_DOUBLE:         0.1
epics> dbpf ao 0
DBF_DOUBLE:         0
and here’s what my camonitor output looked like. I started it immediately after the softIoc, before the first dbpf command above:
woz$ camonitor 'ai.{dbnd:{abs:1.5}}' 'ao.{dbnd:{abs:1.5}}'
ai.{dbnd:{abs:1.5}}            <undefined> 0 UDF INVALID
ao.{dbnd:{abs:1.5}}            <undefined> 0 UDF INVALID
ai.{dbnd:{abs:1.5}}            2021-10-02 17:08:32.684729 10
ai.{dbnd:{abs:1.5}}            2021-10-02 17:08:39.867667 0
ai.{dbnd:{abs:1.5}}            2021-10-02 17:09:05.595295 1.501
ao.{dbnd:{abs:1.5}}            2021-10-02 17:09:32.741622 1.501
ao.{dbnd:{abs:1.5}}            2021-10-02 17:10:02.573699 0
The first two lines that show the undefined timestamp and UDF/Invalid alarm give the initial channel values as zero, then after testing with 10 and 0 there were no monitors posted until the value went over the deadband.
If you’re seeing something different, can you post your complete output from camonitor?
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: channel and pv deadband Michael Davidsaver via Tech-talk
channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
Re: channel and pv deadband Kasemir, Kay via Tech-talk
Re: channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
Re: channel and pv deadband Johnson, Andrew N. via Tech-talk
Prev: Re: channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
Next: Re: channel and pv deadband Michael Davidsaver via Tech-talk
