Subject: Re: High Voltage PS with RS-232 serial port
To: Hasan SANSAR <[email protected]>
Cc: [email protected]
Date: Fri, 1 Oct 2021 09:08:38 -0700
What does
ls -l /dev/ttyS*
show?
Perhaps this is just a permission issue?
On Oct 1, 2021, at 4:33 AM, Hasan SANSAR via Tech-talk <[email protected]> wrote:
Hi all,
We were using Glassman's HVPS with RS-232 serial port connection diretcly on CentOS 7.4 on MOXA DA-682A. And I updated CentOS to 7.9. after that MOXA PC started to not recognizing RS-232 serial connection. So, we are using High Voltage PS with TCP/IP converter  for temporary reason.
I'm getting same error in here at tech-talk discussion:
https://epics.anl.gov/tech-talk/2013/msg01079.php
> drvAsynSerialPortConfigure("L0","/dev/ttyS0",0,0,0)
> asynSetOption("L0", -1, "baud", "9600")
> setOption failed tcsetattr failed: Input/output error
How can I solve this problem and how can I connect to this device over RS-232 port again?
Eric Norum
High Voltage PS with RS-232 serial port Hasan SANSAR via Tech-talk
Prev: Re: channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
Next: Re: High Voltage PS with RS-232 serial port Eric Norum via Tech-talk
Prev: High Voltage PS with RS-232 serial port Hasan SANSAR via Tech-talk
