Subject: Re: High Voltage PS with RS-232 serial port
To: Hasan SANSAR <[email protected]>
Cc: [email protected]
Date: Fri, 1 Oct 2021 09:19:39 -0700
Here’s a mention of the error message that you reported:
The final message in that thread says:
The issue was udev loading smsc_ircc2. As soon as smsc_ircc2 is
loaded, the serial port shows the behavior listed above. Unloading the
module does not help, a reboot is needed.
I have now solved the issue locally by blacklisting smsc_ircc2 and
hope that I didn't break anything in this process.
Other google search results on "LSR safety check engaged!” imply that perhaps something is messed up in the kernel.
On Oct 1, 2021, at 4:33 AM, Hasan SANSAR via Tech-talk <[email protected]> wrote:
Hi all,
We were using Glassman's HVPS with RS-232 serial port connection diretcly on CentOS 7.4 on MOXA DA-682A. And I updated CentOS to 7.9. after that MOXA PC started to not recognizing RS-232 serial connection. So, we are using High Voltage PS with TCP/IP converter  for temporary reason.
I'm getting same error in here at tech-talk discussion:
https://epics.anl.gov/tech-talk/2013/msg01079.php
> drvAsynSerialPortConfigure("L0","/dev/ttyS0",0,0,0)
> asynSetOption("L0", -1, "baud", "9600")
> setOption failed tcsetattr failed: Input/output error
How can I solve this problem and how can I connect to this device over RS-232 port again?
.dmesg | grep tty
[    0.000000] console [tty0] enabled
[250769.622609] ttyS0: LSR safety check engaged!
[251729.802651] ttyS0: LSR safety check engaged!
[251733.905599] ttyS0: LSR safety check engaged!
[251733.910846] ttyS0: LSR safety check engaged!
[251734.006180] ttyS0: LSR safety check engaged!
Eric Norum
Re: High Voltage PS with RS-232 serial port Maren Purves via Tech-talk
High Voltage PS with RS-232 serial port Hasan SANSAR via Tech-talk
Prev: Re: High Voltage PS with RS-232 serial port Eric Norum via Tech-talk
Next: Re: High Voltage PS with RS-232 serial port Maren Purves via Tech-talk
