>> Can I just copy these folders with the protobuf files in it and save them off, if needed I would drop them back into their respective directories if I wanted to use them again?
Yes to both. These files are also append-only files; so you can use incremental backups if your backup system supports it.
>> Am I able to just delete the ArchiverStores after STS MTS LTS have been saved off and they will get remade or would I need to go about this differently?
Don't understand this question though. The files here contain actual data; if you delete these files; you will be losing data.
Murali
- Re: Backing up the ArchiverStores STS MTS LTS Epic Archiver Appliance Ralph Lange via Tech-talk
Problems encountered in installing genSub module gjzhai--- via Tech-talk
Introducing Python package to create Phoebus screens Tynan Ford via Tech-talk
<2021>
2025
2026
Fw: Backing up the ArchiverStores STS MTS LTS Epic Archiver Appliance Wilson, Andy (DLSLtd, RAL, LSCI) via Tech-talk
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
