1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: EPICS Time provider, MRF TImestamp
From: GAGET Alexis via Tech-talk <[email protected]>
Date: Tue, 12 Oct 2021 14:37:21 +0000
Dear All,
I have a MRF Timing system that is working well. I’m using Timestamp from the EPICS driver mrfioc2. I can see in my MRF IOCs that the Time provider is the “EVR”, and then all my PVs in those MRF IOCS are well timestamped.
But obviously in my other IOC (soft IOC or any other device IOC), I haven’t MRF Time provider and they are using the “OS Clock” as a timestamp reference.  I’d like to use the MRF Timestamp as reference for any IOCs in my system. Is there a way to do that ? declaring a new time provider from a PV ? I’ve tried to test to declare a new time provider without any success until then, if you have example it’s welcome.
Sure my OS can be synchronized by NTP, but I have bad experience with NTP and I’d like to know if there is an EPICS way to do that.
Thanks for your consideration
Alexis GAGET
CEA Saclay - DRF/Irfu/DIS/LDISC
Re: EPICS Time provider, MRF TImestamp Michael Davidsaver via Tech-talk
Re: EPICS Time provider, MRF TImestamp Johnson, Andrew N. via Tech-talk
Prev: Re: channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
Next: Re: EPICS Time provider, MRF TImestamp Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: How to access PSI Elog data from other web clients Wang, Lin via Tech-talk
