Subject: Re: channel and pv deadband
From: "Mezger Anton Christian \(PSI\) via Tech-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 12 Oct 2021 10:25:34 +0000
Hi Michael,
Sorry, but could you test once more, because I thought it worked fine, but it seems that the dbnd does not work any more. I get now all changes, when I replace dbnd.c with this patch
Best regards
Anton
On 3 Oct 2021, a
t 17:18, Michael Davidsaver <[email protected]> wrote:
On 10/3/21 2:28 AM, Mezger Anton Christian (PSI) via Tech-talk wrote:
... Should not the real value 0 then be given later from the monitor when 0 is written?
It should, but until recently this wasn't possible.  A filter
did not have access to the event mask (DBE_*), and so could
not distinguish DBE_VALUE from DBE_VALUE|DBE_ALARM.
This is now possible.  If you would care to test:
https://github.com/epics-base/epics-base/pull/204
Re: channel and pv deadband Michael Davidsaver via Tech-talk
channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
Re: channel and pv deadband Kasemir, Kay via Tech-talk
Re: channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
Re: channel and pv deadband Johnson, Andrew N. via Tech-talk
Prev: Re: Epics Archiver Appliance Storage Question Wilson, Andy (DLSLtd, RAL, LSCI) via Tech-talk
Next: EPICS Time provider, MRF TImestamp GAGET Alexis via Tech-talk
Prev: Re: channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
Next: Re: channel and pv deadband Michael Davidsaver via Tech-talk
