1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: channel and pv deadband
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Mezger Anton Christian (PSI)" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 12 Oct 2021 08:41:03 -0700
On 10/12/21 3:25 AM, Mezger Anton Christian (PSI) wrote:
> Hi Michael,
> Sorry, but could you test once more, because I thought it worked fine, but it seems that the dbnd does not work any more. I get now all changes, when I replace dbnd.c with this patch
Can you test with a checkout of the proposed change directly?
https://github.com/epics-base/epics-base/pull/204
I'm still seeing the same behavior as previous.  See below
with only some whitespace added for readability.
> $ cat mailbox.db
> record(ai, "test") {}> $ ./bin/linux-x86_64/softIoc -d mailbox.db
> Starting iocInit
> ## EPICS R7.0.6.2-DEV
> ## Rev. R7.0.6.1-43-gb85ccbf67414a9dc9674
> iocRun: All initialization complete
> epics> system "./bin/linux-x86_64/camonitor 'test.{dbnd:{abs:1.5}}' &"
> epics>
> test.{dbnd:{abs:1.5}}          <undefined> 0 UDF INVALID
> epics> dbpf test 0
> DBF_DOUBLE:         0
> epics>
> test.{dbnd:{abs:1.5}}          2021-10-12 08:30:14.383609 0
> epics> dbpf test 1
> DBF_DOUBLE:         1
> epics> dbpf test 1.5
> DBF_DOUBLE:         1.5
> epics> dbpf test 1.6
> DBF_DOUBLE:         1.6
> epics>
> test.{dbnd:{abs:1.5}}          2021-10-12 08:30:25.475097 1.6
> epics> dbpf test 0
> DBF_DOUBLE:         0
> epics>
> test.{dbnd:{abs:1.5}}          2021-10-12 08:30:31.450680 0
channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
Re: channel and pv deadband Kasemir, Kay via Tech-talk
Re: channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
Re: channel and pv deadband Johnson, Andrew N. via Tech-talk
Re: channel and pv deadband Michael Davidsaver via Tech-talk
Prev: Re: EPICS Time provider, MRF TImestamp Johnson, Andrew N. via Tech-talk
Next: RE: Epics Archiver Appliance Storage Question Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
Next: High Voltage PS with RS-232 serial port Hasan SANSAR via Tech-talk
