Subject: Re: channel and pv deadband
From: "Mezger Anton Christian \(PSI\) via Tech-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 4 Oct 2021 18:16:59 +0000
Hi Michael,
many thanks. I tested it out with the changes in dbnd.c and it works perfectly well.
epics is great!
best regards
Anton
Sent: Sunday, October 3, 2021 5:18:59 PM
To: Mezger Anton Christian (PSI)
Cc: EPICS tech-talk; Johnson, Andrew N.; Ralph Lange
On 10/3/21 2:28 AM, Mezger Anton Christian (PSI) via Tech-talk wrote:
> ... Should not the real value 0 then be given later from the monitor when 0 is written?
It should, but until recently this wasn't possible.  A filter
did not have access to the event mask (DBE_*), and so could
not distinguish DBE_VALUE from DBE_VALUE|DBE_ALARM.
This is now possible.  If you would care to test:
https://github.com/epics-base/epics-base/pull/204
channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
Re: channel and pv deadband Kasemir, Kay via Tech-talk
Re: channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
Re: channel and pv deadband Johnson, Andrew N. via Tech-talk
Re: channel and pv deadband Michael Davidsaver via Tech-talk
Prev: Re: Problems encountered in installing genSub module Johnson, Andrew N. via Tech-talk
Next: Odd characters in temperatures showing in Phoebus Leblanc, Gregory via Tech-talk
Prev: Re: channel and pv deadband Michael Davidsaver via Tech-talk
Next: Re: channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
