On Oct 3, 2021, at 10:38 PM, gjzhai via Tech-talk <[email protected]> wrote:
Hello!When I install the gensub module, the error message is displayed as follows when compiling
make[2]: /usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxWorks-6.9/x86-linux2/bin/ccppc: Command not found
make[2]: *** [genSubRecord.0] Error 127
Thank you for your time. I am looking forward to your reply.
The above path is almost the same as the install path to the VxWorks 6.9 C compiler for PowerPC at the APS, except for the ‘W’ character in ‘4.3.3-vxWorks-6.9’ which is lower-case in our installation.
Are you wanting to build this code for PowerPC on VxWorks? I know that Gemini (who created the genSub) also use that architecture, but I don’t see how their gensub module could be causing the above issue. If you are working with or for Gemini you should
probably ask them (or Andy Foster) for help.
Do you really need the gensub module at all? A cut-down version of the genSubRecord was added to EPICS Base called the aSub record, and for most applications that should be able to perform the same functions. The aSub is being maintained as part of EPICS
Base, whereas I don’t know the status of the gensub module.
- Andrew
Complexity comes for free, simplicity you have to work for.
- Problems encountered in installing genSub module gjzhai--- via Tech-talk
Re: Backing up the ArchiverStores STS MTS LTS Epic Archiver Appliance Shankar, Murali via Tech-talk
Re: channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
<2021>
2025
2026
Introducing Python package to create Phoebus screens Tynan Ford via Tech-talk
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
