Subject: Re: Backing up the ArchiverStores STS MTS LTS Epic Archiver Appliance
From: "Shankar, Murali via Tech-talk" <[email protected]>
To: Ralph Lange <[email protected]>
Date: Mon, 4 Oct 2021 15:41:14 +0000
>> Can you safely move away the files?
Given the usual caveats about some processes deleting files while other processes are writing/reading from them; you can operate on these files independent of the archiver. So, in some cases, you might see some exceptions about missing files etc but otherwise things should continue to function as usual. Hope this answers the question...
Murali
Sent: Monday, October 4, 2021 8:21 AM
To: Shankar, Murali <[email protected]>
Cc: [email protected] <[email protected]>
On Mon, 4 Oct 2021 at 16:54, Shankar, Murali via Tech-talk <[email protected]> wrote:
>> Am I able to just delete the ArchiverStores after STS MTS LTS have been saved off and they will get remade or would I need to go about this differently?
Don't understand this question though. The files here contain actual data; if you delete these files; you will be losing data.
I think the question can be rephrased as: Can you safely move away the files?
Cheers,
~Ralph
RE: Backing up the ArchiverStores STS MTS LTS Epic Archiver Appliance Manoussakis, Adamandios via Tech-talk
Re: Backing up the ArchiverStores STS MTS LTS Epic Archiver Appliance Shankar, Murali via Tech-talk
Re: Backing up the ArchiverStores STS MTS LTS Epic Archiver Appliance Ralph Lange via Tech-talk
Prev: Re: Backing up the ArchiverStores STS MTS LTS Epic Archiver Appliance Ralph Lange via Tech-talk
Next: Re: Problems encountered in installing genSub module Johnson, Andrew N. via Tech-talk
Next: RE: Backing up the ArchiverStores STS MTS LTS Epic Archiver Appliance Manoussakis, Adamandios via Tech-talk
