1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: "rpcgen: Command not found" When asyn
To: tech-talk <[email protected]>
Date: Thu, 14 Oct 2021 12:26:12 +0800 (CST)
Hi all,
    I use centos 8(64), base7.0.6.1,asyn from the github( https://github.com/epics-modules  )
    When I make tha asyn module, I met the question.
make[2]: Entering directory '/home/liangyx/synApps/support/asyn-master/asyn/O.linux-x86_64'
cp ../vxi11/vxi11intr.rpcl .
rpcgen  vxi11intr.rpcl
make[2]: rpcgen: Command not found
cp ../vxi11/vxi11core.rpcl .
rpcgen  vxi11core.rpcl
make[2]: *** No rule to make target 'vxi11core_xdr.c', needed by 'vxi11core_xdr.o'.  Stop.
make[2]: Leaving directory '/home/liangyx/synApps/support/asyn-master/asyn/O.linux-x86_64'
make[1]: *** [/home/liangyx/base-7.0.6.1/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[1]: Leaving directory '/home/liangyx/synApps/support/asyn-master/asyn'
make: *** [/home/liangyx/base-7.0.6.1/configure/RULES_DIRS:85: asyn.install] Error 2
I have tried "yum install glibc-utils and yum install glibc."       Neither worked.
How I could fix it?
Thanks
Liang
Re: "rpcgen: Command not found" When asyn Gerrit Kühn via Tech-talk
Re: "rpcgen: Command not found" When asyn Matt Clarke via Tech-talk
Prev: Re: Support for recent general purpose oscilloscopes? Brown, Garth via Tech-talk
Next: Re: "rpcgen: Command not found" When asyn Gerrit Kühn via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Periodically calling shell functions in an IOC Hu, Yong via Tech-talk
