Subject: Re: Periodically calling shell functions in an IOC
To: Ralph Lange <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Fri, 15 Oct 2021 13:41:34 +0000
Hi Andrew W.:
If you do not want to hack “streamReload”, you may try this: https://github.com/NSLS-II/elauncher
It is an EPICS device support for easy script launcher: one can run a Python (or shell, or anything you can use in a Linux terminal) script inside an IOC through a bo record. Michael Davidsaver developed it at NSLS-II a few years ago, specifically for use cases like yours.
You can change how fast you want to execute your script by simply changing the field of SCAN either from a command caput or from a CS-Studio button:
caput elauncherTestShell.SCAN 3
caput elauncherTestShell.SCAN Passive
caget -d GR_ENUM elauncherTestShell.SCAN
    Native data type: DBF_ENUM
    Request type:     DBR_GR_ENUM
    Element count:    1
    Value:            1 second
    Status:           NO_ALARM
    Severity:         NO_ALARM
    Enums:            (10)
                      [ 0] Passive
                      [ 1] Event
                      [ 2] I/O Intr
                      [ 3] 10 second
                      [ 4] 5 second
                      [ 5] 2 second
                      [ 6] 1 second
                      [ 7] .5 second
                      [ 8] .2 second
                      [ 9] .1 second
Cheers,
Yong
From: Tech-talk <[email protected]> on behalf of "[email protected]" <[email protected]>
Reply-To: Ralph Lange <[email protected]>
Date: Thursday, October 14, 2021 at 4:56 AM
On Wed, 13 Oct 2021 at 22:45, Wang, Andrew via Tech-talk <[email protected]> wrote:
I have a question regarding the use of shell functions with in the IOC shell. There is a shell function from StreamDevice called streamReload that I am interested in using periodically like every 30 seconds. What is the preferred method, if there are any, for doing so? Also, is there a potential way for calling that shell function within the SNL sequencer?
This is unusual as operating mode. The reload function is intended for development / rapid prototyping (testing a protocol change without rebooting the IOC).
So - please be careful with respect to possible side effects: What happens if the protocol file gets corrupted, a typo is being introduced, the disk (or nfs) is down etc. How do you detect such a situation? How do you fix it?
Needs testing.
Cheers,
~Ralph
Periodically calling shell functions in an IOC Wang, Andrew via Tech-talk
Re: Periodically calling shell functions in an IOC Ralph Lange via Tech-talk
Prev: Does EPICS support MVME3100 under Linux? Dmitry Yu. Bolkhovityanov via Tech-talk
Next: Re: Channel Archiver data into Archiver Appliance? Hu, Yong via Tech-talk
Prev: Re: Periodically calling shell functions in an IOC Ralph Lange via Tech-talk
Next: "rpcgen: Command not found" When asyn 网易邮件中心 via Tech-talk
