Hi Dmitry,
On Oct 15, 2021, at 2:40 AM, Dmitry Yu. Bolkhovityanov via Tech-talk < [email protected]> wrote:
The subject says it all: does EPICS VME subsystem support MVME3100 under Linux, or is RTEMS mandatory?
The EPICS devLib API can be used on Linux if you have a suitable implementation of the target-specific support for it (a
struct devLibVME object with pointers to the necessary routines). However there certainly isn’t one included with EPICS for Linux on the MVME3100 board, and I’m not sure if anyone else in the community has ever developed one.
In general Linux won’t have good support for VME interrupts because the IOC runs as a regular process in user space and no matter how the associated kernel driver signals the arrival of an interrupt to user-space it will not be fast.
RTEMS isn’t mandatory, but it might be the easiest way to control VME I/O devices from that board.
Alternatively, does anybody have any experience with alternative VME SBCs, such as Duagon (ex-MEN) A25, Kontron ALMA2f-based boards, or Concurrent Technologies Tundra-based x86 boards?
Not personally. Be aware that most existing EPICS drivers for VME I/O cards have been written for big-endian CPUs (m68k and/or PowerPC) and might need changes to work on little-endian CPUs (Intel/AMD) to swap the byte order when accessing registers
on other VME cards. Some VME interfaces perform byte-swapping automatically though, so it may depend on the specific CPU board whether you need to do that or not.
- Andrew
Complexity comes for free, simplicity you have to work for.
- Does EPICS support MVME3100 under Linux? Dmitry Yu. Bolkhovityanov via Tech-talk
Metadata for an NTTable Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
aravisGigE driver for AVT Manta camera Hasan SANSAR via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
