Subject: aravisGigE driver for AVT Manta camera
From: Hasan SANSAR via Tech-talk <[email protected]>
To: [email protected]
Date: Sat, 16 Oct 2021 16:58:54 +0300
We are using Baumer CCD cameras with aravisGigE driver and we have a AVT Manta G201-B camera. I'm trying to add aravisGigE's st.cmd this camera but I failed. The arv-tool-0.6 can recognize the camera and template file can be built for the camera, but when I run the start_epics file after changing st.cmd, I can connect to camera but, cannot get raw data for images and vision.
I have set  to EPICS_CA_MAX_ARRAY_BYTES to .bashrc and datasources of CSS as 1624*1234*32 and, I have set new buffer memory values for different increasing values and so, I couldn't get images. (I run aravisGigE driver on virtual CentOS 7.9 on real Linux Mint 21.04. Should I change buffer memory values and EPICS_CA_MAX_ARRAY_BYTES for Linux Mint? (This situation was not needed for Baumer cameras.))
How can I solve this problem?
I'm sending related output of start_epics.
Thanks in advance.
Best regards.
Hasan.
output of start_epics:
[cam@localhost iocAravisGigE]$ ./start_epics
< envPaths
epicsEnvSet("IOC","iocAravisGigE")
epicsEnvSet("TOP","/opt/EPICS/support/Dedektor/aravisGigE/iocs/aravisGigEIOC")
epicsEnvSet("ARAVISGIGE","/opt/EPICS/support/Dedektor/aravisGigE/iocs/aravisGigEIOC/../..")
epicsEnvSet("SUPPORT","/opt/EPICS/support")
epicsEnvSet("ASYN","/opt/EPICS/support/asyn")
epicsEnvSet("AREA_DETECTOR","/opt/EPICS/support/Dedektor")
epicsEnvSet("ADSUPPORT","/opt/EPICS/support/Dedektor/ADSupport")
epicsEnvSet("ADCORE","/opt/EPICS/support/Dedektor/ADCore")
epicsEnvSet("AUTOSAVE","/opt/EPICS/support/autosave")
epicsEnvSet("BUSY","/opt/EPICS/support/busy")
epicsEnvSet("CALC","/opt/EPICS/support/calc")
epicsEnvSet("SNCSEQ","/opt/EPICS/support/sequencer")
epicsEnvSet("SSCAN","/opt/EPICS/support/sscan")
epicsEnvSet("DEVIOCSTATS","/opt/EPICS/support/iocStats")
epicsEnvSet("EPICS_BASE","/opt/EPICS/epics-base")
errlogInit(20000)
dbLoadDatabase("/opt/EPICS/support/Dedektor/aravisGigE/iocs/aravisGigEIOC/dbd/aravisGigEApp.dbd")
aravisGigEApp_registerRecordDeviceDriver(pdbbase)
# Prefix for all records
epicsEnvSet("PREFIX", "BL:DCC:")
# The port name for the detector
epicsEnvSet("PORT",   "ARV1")
# The queue size for all plugins
epicsEnvSet("QSIZE",  "20")
# The maximim image width; used for row profiles in the NDPluginStats plugin
epicsEnvSet("XSIZE",  "1624")
# The maximim image height; used for column profiles in the NDPluginStats plugin
epicsEnvSet("YSIZE",  "1234")
# The maximum number of time series points in the NDPluginStats plugin
epicsEnvSet("NCHANS", "2048")
# The maximum number of frames buffered in the NDPluginCircularBuff plugin
epicsEnvSet("CBUFFS", "500")
# The search path for database files
epicsEnvSet("EPICS_DB_INCLUDE_PATH", "/opt/EPICS/support/Dedektor/ADCore/db")
dbLoadRecords("/opt/EPICS/support/Dedektor/aravisGigE/iocs/aravisGigEIOC/../../iocs/aravisGigEIOC/iocBoot/iocAravisGigE/Cam_Checker.db")
aravisCameraConfig("ARV1", "Allied Vision Technologies-50-0503326564")
aravisCamera: Looking for camera 'Allied Vision Technologies-50-0503326564'...
aravisCamera: Your tick frequency is 36000000
So your timestamp resolution is 27.777778 ns
aravisCamera: Done.
aravisCamera: Getting feature list...
aravisCamera: Done.
dbLoadRecords("/opt/EPICS/support/Dedektor/aravisGigE/iocs/aravisGigEIOC/../../db/AVT_Manta_G201B.template","P=BL:DCC:,R=cam1:,PORT=ARV1,ADDR=0,TIMEOUT=1")
#aravisCameraConfig("ARV2", "Baumer Optronic-0402920514")
#dbLoadRecords("$(ARAVISGIGE)/db/Baumer_VLG20M.template","P=$(PREFIX),R=cam2:,PORT=ARV2,ADDR=0,TIMEOUT=1")
asynSetTraceMask("ARV1",0,0x21)
dbLoadRecords("/opt/EPICS/support/Dedektor/aravisGigE/iocs/aravisGigEIOC/../../db/aravisCamera.template", "P=BL:DCC:,R=cam1:,PORT=ARV1,ADDR=0,TIMEOUT=1")
#asynSetTraceMask("ARV2",0,0x21)
#dbLoadRecords("$(ARAVISGIGE)/db/aravisCamera.template", "P=$(PREFIX),R=cam2:,PORT=ARV2,ADDR=0,TIMEOUT=1")
# Create a standard arrays plugin
NDStdArraysConfigure("Image1", 5, 0, "ARV1", 0, 0)
# Allow for cameras up to 2048x2048x3 for RGB
dbLoadRecords("/opt/EPICS/support/Dedektor/ADCore/db/NDStdArrays.template", "P=BL:DCC:,R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1,TYPE=Int16,FTVL=SHORT,NELEMENTS=12582912")
# Load all other plugins using commonPlugins.cmd
< /opt/EPICS/support/Dedektor/ADCore/iocBoot/commonPlugins.cmd
# This is an example file for creating plugins
# It uses the following environment variable macros
# Many of the parameters defined in this file are also in commonPlugins_settings.req so if autosave is being
# use the autosave value will replace the value passed to this file.
# $(PREFIX)      Prefix for all records
# $(PORT)        The port name for the detector.  In autosave.
# $(QSIZE)       The queue size for all plugins.  In autosave.
# $(XSIZE)       The maximum image width; used to set the maximum size for row profiles in the NDPluginStats plugin and 1-D FFT
#                   profiles in NDPluginFFT.
# $(YSIZE)       The maximum image height; used to set the maximum size for column profiles in the NDPluginStats plugin
# $(NCHANS)      The maximum number of time series points in the NDPluginStats, NDPluginROIStats, and NDPluginAttribute plugins
# $(CBUFFS)      The maximum number of frames buffered in the NDPluginCircularBuff plugin
# $(MAX_THREADS) The maximum number of threads for plugins which can run in multiple threads. Defaults to 5.
# Create a netCDF file saving plugin
NDFileNetCDFConfigure("FileNetCDF1", 20, 0, "ARV1", 0)
dbLoadRecords("NDFileNetCDF.template","P=BL:DCC:,R=netCDF1:,PORT=FileNetCDF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
# Create a TIFF file saving plugin
NDFileTIFFConfigure("FileTIFF1", 20, 0, "ARV1", 0)
dbLoadRecords("NDFileTIFF.template",  "P=BL:DCC:,R=TIFF1:,PORT=FileTIFF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
# Create a JPEG file saving plugin
NDFileJPEGConfigure("FileJPEG1", 20, 0, "ARV1", 0)
dbLoadRecords("NDFileJPEG.template",  "P=BL:DCC:,R=JPEG1:,PORT=FileJPEG1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
# Create a NeXus file saving plugin
NDFileNexusConfigure("FileNexus1", 20, 0, "ARV1", 0)
dbLoadRecords("NDFileNexus.template", "P=BL:DCC:,R=Nexus1:,PORT=FileNexus1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
# Create an HDF5 file saving plugin
NDFileHDF5Configure("FileHDF1", 20, 0, "ARV1", 0)
dbLoadRecords("NDFileHDF5.template",  "P=BL:DCC:,R=HDF1:,PORT=FileHDF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
# Create a Magick file saving plugin
#NDFileMagickConfigure("FileMagick1", $(QSIZE), 0, "$(PORT)", 0)
#dbLoadRecords("NDFileMagick.template","P=$(PREFIX),R=Magick1:,PORT=FileMagick1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
# Create 4 ROI plugins
NDROIConfigure("ROI1", 20, 0, "ARV1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDROI.template",       "P=BL:DCC:,R=ROI1:,  PORT=ROI1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
NDROIConfigure("ROI2", 20, 0, "ARV1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDROI.template",       "P=BL:DCC:,R=ROI2:,  PORT=ROI2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
NDROIConfigure("ROI3", 20, 0, "ARV1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDROI.template",       "P=BL:DCC:,R=ROI3:,  PORT=ROI3,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
NDROIConfigure("ROI4", 20, 0, "ARV1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDROI.template",       "P=BL:DCC:,R=ROI4:,  PORT=ROI4,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
# Create 8 ROIStat plugins
NDROIStatConfigure("ROISTAT1", 20, 0, "ARV1", 0, 8, 0, 0, 0, 0, 5)
dbLoadRecords("NDROIStat.template",   "P=BL:DCC:,R=ROIStat1:  ,PORT=ROISTAT1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=BL:DCC:,R=ROIStat1:1:,PORT=ROISTAT1,ADDR=0,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=BL:DCC:,R=ROIStat1:2:,PORT=ROISTAT1,ADDR=1,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=BL:DCC:,R=ROIStat1:3:,PORT=ROISTAT1,ADDR=2,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=BL:DCC:,R=ROIStat1:4:,PORT=ROISTAT1,ADDR=3,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=BL:DCC:,R=ROIStat1:5:,PORT=ROISTAT1,ADDR=4,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=BL:DCC:,R=ROIStat1:6:,PORT=ROISTAT1,ADDR=5,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=BL:DCC:,R=ROIStat1:7:,PORT=ROISTAT1,ADDR=6,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=BL:DCC:,R=ROIStat1:8:,PORT=ROISTAT1,ADDR=7,TIMEOUT=1,NCHANS=2048")
# Create a processing plugin
NDProcessConfigure("PROC1", 20, 0, "ARV1", 0, 0, 0)
dbLoadRecords("NDProcess.template",   "P=BL:DCC:,R=Proc1:,  PORT=PROC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
# Create a TIFF file plugin to read dark and flatfield images into the processing plugin
NDFileTIFFConfigure("PROC1TIFF", 20, 0, "ARV1", 0)
dbLoadRecords("NDFileTIFF.template",  "P=BL:DCC:,R=Proc1:TIFF:,PORT=PROC1TIFF,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
# Create a scatter plugin
NDScatterConfigure("SCATTER1", 20, 0, "ARV1", 0, 0, 0)
dbLoadRecords("NDScatter.template",   "P=BL:DCC:,R=Scatter1:,  PORT=SCATTER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
# Create a gather plugin with 8 ports
NDGatherConfigure("GATHER1", 20, 0, 8, 0, 0)
dbLoadRecords("NDGather.template",   "P=BL:DCC:,R=Gather1:, PORT=GATHER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
dbLoadRecords("NDGatherN.template",   "P=BL:DCC:,R=Gather1:, N=1, PORT=GATHER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
dbLoadRecords("NDGatherN.template",   "P=BL:DCC:,R=Gather1:, N=2, PORT=GATHER1,ADDR=1,TIMEOUT=1,NDARRAY_PORT=ARV1")
dbLoadRecords("NDGatherN.template",   "P=BL:DCC:,R=Gather1:, N=3, PORT=GATHER1,ADDR=2,TIMEOUT=1,NDARRAY_PORT=ARV1")
dbLoadRecords("NDGatherN.template",   "P=BL:DCC:,R=Gather1:, N=4, PORT=GATHER1,ADDR=3,TIMEOUT=1,NDARRAY_PORT=ARV1")
dbLoadRecords("NDGatherN.template",   "P=BL:DCC:,R=Gather1:, N=5, PORT=GATHER1,ADDR=4,TIMEOUT=1,NDARRAY_PORT=ARV1")
dbLoadRecords("NDGatherN.template",   "P=BL:DCC:,R=Gather1:, N=6, PORT=GATHER1,ADDR=5,TIMEOUT=1,NDARRAY_PORT=ARV1")
dbLoadRecords("NDGatherN.template",   "P=BL:DCC:,R=Gather1:, N=7, PORT=GATHER1,ADDR=6,TIMEOUT=1,NDARRAY_PORT=ARV1")
dbLoadRecords("NDGatherN.template",   "P=BL:DCC:,R=Gather1:, N=8, PORT=GATHER1,ADDR=7,TIMEOUT=1,NDARRAY_PORT=ARV1")
# Create 5 statistics plugins
NDStatsConfigure("STATS1", 20, 0, "ARV1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=BL:DCC:,R=Stats1:,  PORT=STATS1,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1624,YSIZE=1234,NCHANS=2048,NDARRAY_PORT=ARV1")
NDTimeSeriesConfigure("STATS1_TS", 20, 0, "STATS1", 1, 23)
dbLoadRecords("/opt/EPICS/support/Dedektor/ADCore/db/NDTimeSeries.template",  "P=BL:DCC:,R=Stats1:TS:, PORT=STATS1_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS1,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
NDStatsConfigure("STATS2", 20, 0, "ROI1",    0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=BL:DCC:,R=Stats2:,  PORT=STATS2,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1624,YSIZE=1234,NCHANS=2048,NDARRAY_PORT=ARV1")
NDTimeSeriesConfigure("STATS2_TS", 20, 0, "STATS2", 1, 23)
dbLoadRecords("/opt/EPICS/support/Dedektor/ADCore/db/NDTimeSeries.template",  "P=BL:DCC:,R=Stats2:TS:, PORT=STATS2_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS2,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
NDStatsConfigure("STATS3", 20, 0, "ROI2",    0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=BL:DCC:,R=Stats3:,  PORT=STATS3,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1624,YSIZE=1234,NCHANS=2048,NDARRAY_PORT=ARV1")
NDTimeSeriesConfigure("STATS3_TS", 20, 0, "STATS3", 1, 23)
dbLoadRecords("/opt/EPICS/support/Dedektor/ADCore/db/NDTimeSeries.template",  "P=BL:DCC:,R=Stats3:TS:, PORT=STATS3_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS3,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
NDStatsConfigure("STATS4", 20, 0, "ROI3",    0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=BL:DCC:,R=Stats4:,  PORT=STATS4,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1624,YSIZE=1234,NCHANS=2048,NDARRAY_PORT=ARV1")
NDTimeSeriesConfigure("STATS4_TS", 20, 0, "STATS4", 1, 23)
dbLoadRecords("/opt/EPICS/support/Dedektor/ADCore/db/NDTimeSeries.template",  "P=BL:DCC:,R=Stats4:TS:, PORT=STATS4_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS4,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
NDStatsConfigure("STATS5", 20, 0, "ROI4",    0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=BL:DCC:,R=Stats5:,  PORT=STATS5,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1624,YSIZE=1234,NCHANS=2048,NDARRAY_PORT=ARV1")
NDTimeSeriesConfigure("STATS5_TS", 20, 0, "STATS5", 1, 23)
dbLoadRecords("/opt/EPICS/support/Dedektor/ADCore/db/NDTimeSeries.template",  "P=BL:DCC:,R=Stats5:TS:, PORT=STATS5_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS5,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
# Create a transform plugin
NDTransformConfigure("TRANS1", 20, 0, "ARV1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDTransform.template", "P=BL:DCC:,R=Trans1:,  PORT=TRANS1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
# Create an overlay plugin with 8 overlays
NDOverlayConfigure("OVER1", 20, 0, "ARV1", 0, 8, 0, 0, 0, 0, 5)
dbLoadRecords("NDOverlay.template", "P=BL:DCC:,R=Over1:, PORT=OVER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
dbLoadRecords("NDOverlayN.template","P=BL:DCC:,R=Over1:1:,NAME=ROI1,   SHAPE=1,O=Over1:,XPOS=BL:DCC:ROI1:MinX_RBV,YPOS=BL:DCC:ROI1:MinY_RBV,XSIZE=BL:DCC:ROI1:SizeX_RBV,YSIZE=BL:DCC:ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=BL:DCC:,R=Over1:2:,NAME=ROI2,   SHAPE=1,O=Over1:,XPOS=BL:DCC:ROI2:MinX_RBV,YPOS=BL:DCC:ROI2:MinY_RBV,XSIZE=BL:DCC:ROI2:SizeX_RBV,YSIZE=BL:DCC:ROI2:SizeY_RBV,PORT=OVER1,ADDR=1,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=BL:DCC:,R=Over1:3:,NAME=ROI3,   SHAPE=1,O=Over1:,XPOS=BL:DCC:ROI3:MinX_RBV,YPOS=BL:DCC:ROI3:MinY_RBV,XSIZE=BL:DCC:ROI3:SizeX_RBV,YSIZE=BL:DCC:ROI3:SizeY_RBV,PORT=OVER1,ADDR=2,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=BL:DCC:,R=Over1:4:,NAME=ROI4,   SHAPE=1,O=Over1:,XPOS=BL:DCC:ROI4:MinX_RBV,YPOS=BL:DCC:ROI4:MinY_RBV,XSIZE=BL:DCC:ROI4:SizeX_RBV,YSIZE=BL:DCC:ROI4:SizeY_RBV,PORT=OVER1,ADDR=3,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=BL:DCC:,R=Over1:5:,NAME=Cursor1,SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=4,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=BL:DCC:,R=Over1:6:,NAME=Cursor2,SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=5,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=BL:DCC:,R=Over1:7:,NAME=Box1,   SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=6,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=BL:DCC:,R=Over1:8:,NAME=Box2,   SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=7,TIMEOUT=1")
# Create 2 color conversion plugins
NDColorConvertConfigure("CC1", 20, 0, "ARV1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDColorConvert.template", "P=BL:DCC:,R=CC1:,  PORT=CC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
NDColorConvertConfigure("CC2", 20, 0, "ARV1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDColorConvert.template", "P=BL:DCC:,R=CC2:,  PORT=CC2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
# Create a circular buffer plugin
NDCircularBuffConfigure("CB1", 20, 0, "ARV1", 0, 500, 0)
dbLoadRecords("NDCircularBuff.template", "P=BL:DCC:,R=CB1:,  PORT=CB1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
# Create an NDAttribute plugin with 8 attributes
NDAttrConfigure("ATTR1", 20, 0, "ARV1", 0, 8, 0, 0, 0)
dbLoadRecords("NDAttribute.template",  "P=BL:DCC:,R=Attr1:,    PORT=ATTR1,ADDR=0,TIMEOUT=1,NCHANS=2048,NDARRAY_PORT=ARV1")
dbLoadRecords("NDAttributeN.template", "P=BL:DCC:,R=Attr1:1:,  PORT=ATTR1,ADDR=0,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=BL:DCC:,R=Attr1:2:,  PORT=ATTR1,ADDR=1,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=BL:DCC:,R=Attr1:3:,  PORT=ATTR1,ADDR=2,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=BL:DCC:,R=Attr1:4:,  PORT=ATTR1,ADDR=3,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=BL:DCC:,R=Attr1:5:,  PORT=ATTR1,ADDR=4,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=BL:DCC:,R=Attr1:6:,  PORT=ATTR1,ADDR=5,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=BL:DCC:,R=Attr1:7:,  PORT=ATTR1,ADDR=6,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=BL:DCC:,R=Attr1:8:,  PORT=ATTR1,ADDR=7,TIMEOUT=1,NCHANS=2048")
# Create an FFT plugin
NDFFTConfigure("FFT1", 3, 0, "ARV1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDFFT.template", "P=BL:DCC:, R=FFT1:, PORT=FFT1, ADDR=0, TIMEOUT=1, NDARRAY_PORT=ARV1, NAME=FFT1, NCHANS=1624")
set_requestfile_path("./")
set_requestfile_path("/opt/EPICS/support/Dedektor/ADCore/ADApp/Db")
set_requestfile_path("/opt/EPICS/support/Dedektor/ADCore/iocBoot")
set_savefile_path("./autosave")
set_pass0_restoreFile("auto_settings.sav")
set_pass1_restoreFile("auto_settings.sav")
save_restoreSet_status_prefix("BL:DCC:")
dbLoadRecords("/opt/EPICS/support/autosave/asApp/Db/save_restoreStatus.db", "P=BL:DCC:")
# Optional: load NDPluginPva plugin
#NDPvaConfigure("PVA1", $(QSIZE), 0, "$(PORT)", 0, $(PREFIX)Pva1:Image, 0, 0, 0)
#dbLoadRecords("NDPva.template",  "P=$(PREFIX),R=Pva1:, PORT=PVA1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
# Must start PVA server if this is enabled
#startPVAServer
# Optional: load NDPluginEdge plugin
#NDEdgeConfigure("EDGE1", $(QSIZE), 0, "$(PORT)", 0, 0, 0, 0)
#dbLoadRecords("$(ADPLUGINEDGE)/db/NDEdge.template",  "P=$(PREFIX),R=Edge1:, PORT=EDGE1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
#set_requestfile_path("$(ADPLUGINEDGE)/edgeApp/Db")
# Optional: load scan records
#dbLoadRecords("$(SSCAN)/sscanApp/Db/scan.db", "P=$(PREFIX),MAXPTS1=2000,MAXPTS2=200,MAXPTS3=20,MAXPTS4=10,MAXPTSH=10")
#set_requestfile_path("$(SSCAN)/sscanApp/Db")
# Optional: load sseq record for acquisition sequence
#dbLoadRecords("$(CALC)/calcApp/Db/sseqRecord.db", "P=$(PREFIX), S=AcquireSequence")
#set_requestfile_path("$(CALC)/calcApp/Db")
# Optional: load devIocStats records (requires DEVIOCSTATS module)
#dbLoadRecords("$(DEVIOCSTATS)/db/iocAdminSoft.db", "IOC=$(PREFIX)")
# Optional: load alive record (requires ALIVE module)
#dbLoadRecords("$(ALIVE)/aliveApp/Db/alive.db", "P=$(PREFIX),RHOST=192.168.1.254")
macLib: macro ADPILATUS is undefined (expanding string set_requestfile_path("$(ADPILATUS)/prosilicaApp/Db"))
#asynSetTraceMask("$(PORT)",0,255)
#asynSetTraceMask("$(PORT)",0,3)
iocInit()
Starting iocInit
## EPICS R3.15.8
## EPICS Base built Aug 24 2021
reboot_restore: entry for file 'auto_settings.sav'
reboot_restore: Found filename 'auto_settings.sav' in restoreFileList.
*** restoring from './autosave/auto_settings.sav' at initHookState 6 (before record/device init) ***
reboot_restore: done with file 'auto_settings.sav'
2021/10/15 10:26:42.552 asynPortDriver:drvUserCreate: addr=0, cannot find parameter CURSOR_VAL
BL:DCC:Stats1:CursorVal devAsynFloat64::initCommon drvUserCreate
BL:DCC:Stats2:CursorVal devAsynFloat64::initCommon drvUserCreate
BL:DCC:Stats3:CursorVal devAsynFloat64::initCommon drvUserCreate
2021/10/15 10:26:42.553 asynPortDriver:drvUserCreate: addr=0, cannot find parameter CURSOR_VAL
BL:DCC:Stats4:CursorVal devAsynFloat64::initCommon drvUserCreate
BL:DCC:Stats5:CursorVal devAsynFloat64::initCommon drvUserCreate
aravisCamera: Adding feature DeviceVendorName with value: Allied Vision Technologies
aravisCamera: Adding feature DeviceModelName with value: Manta_G-201B
aravisCamera: Adding feature DeviceFirmwareVersion with value: 00.01.44.04
aravisCamera: Adding feature DeviceID with value: 50-0503326564
aravisCamera: Adding feature DevicePartNumber with value: E0020008
aravisCamera: Adding feature ModelName with value: Manta_G-201B
*** restoring from './autosave/auto_settings.sav' at initHookState 7 (after record/device init) ***
2021/10/15 10:26:43.916 NDPluginDriver::writeInt32 cannot do ProcessPlugin, no input array cached
2021/10/15 10:26:43.916 NDPluginDriver::writeInt32 ERROR, status=3, function=66, value=1, connectedToArrayPort_=1
2021/10/15 10:26:43.918 NDPluginDriver::writeInt32 cannot do ProcessPlugin, no input array cached
2021/10/15 10:26:43.918 NDPluginDriver::writeInt32 ERROR, status=3, function=66, value=1, connectedToArrayPort_=1
2021/10/15 10:26:43.919 NDPluginDriver::writeInt32 cannot do ProcessPlugin, no input array cached
2021/10/15 10:26:43.919 NDPluginDriver::writeInt32 ERROR, status=3, function=66, value=1, connectedToArrayPort_=1
2021/10/15 10:26:43.920 NDPluginDriver::writeInt32 cannot do ProcessPlugin, no input array cached
2021/10/15 10:26:43.920 NDPluginDriver::writeInt32 ERROR, status=3, function=66, value=1, connectedToArrayPort_=1
2021/10/15 10:26:43.922 NDPluginDriver::writeInt32 cannot do ProcessPlugin, no input array cached
2021/10/15 10:26:43.922 NDPluginDriver::writeInt32 ERROR, status=3, function=66, value=1, connectedToArrayPort_=1
# save things every thirty seconds
create_monitor_set("auto_settings.req", 30,"P=BL:DCC:")
save_restore:readReqFile: unable to open file aravisCamera_settings.req. Exiting.
save_restore:readReqFile: unable to open file sseq_settings.req. Exiting.
create_monitor_set("commonPlugin_settings.req",30,"P=BL:DCC:")
commonPlugin_settings.sav: 1070 of 1070 PV's connected
auto_settings.sav: 1086 of 1086 PV's connected
epics>Bad Frame Status: Timeout
Bad Frame Status: Timeout, 10 msgs suppressed
Hasan Sansar
Re: aravisGigE driver for AVT Manta camera Mark Rivers via Tech-talk
Re: aravisGigE driver for AVT Manta camera Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
Prev: Re: Does EPICS support MVME3100 under Linux? Johnson, Andrew N. via Tech-talk
Next: Re: aravisGigE driver for AVT Manta camera Mark Rivers via Tech-talk
Prev: Re: Metadata for an NTTable White, Greg via Tech-talk
