Subject: Re: aravisGigE driver for AVT Manta camera
To: Hasan SANSAR <[email protected]>
Date: Sat, 16 Oct 2021 14:31:41 +0000
Hi Hasan,
I suggest that you change from using aravisGigE to either ADAravis or ADVimba for the Manta camera.  aravisGigE is not longer being maintained, and bugs there will not be fixed.
I think the problem you are having may be that the Manta cameras default to jumbo frames.  I think there is a GenICam feature that is available as an EPICS PV to control the packet size.  If that is larger than 1500 then set it to 1500 and see if that fixes the problem with not being able to stream images.
From: Tech-talk <[email protected]> on behalf of Hasan SANSAR via Tech-talk <[email protected]>
Sent: Saturday, October 16, 2021 8:58 AM
To: [email protected]
Subject: aravisGigE driver for AVT Manta camera
We are using Baumer CCD cameras with aravisGigE driver and we have a AVT Manta G201-B camera. I'm trying to add aravisGigE's st.cmd this camera but I failed. The arv-tool-0.6 can recognize the camera and template file can be built for the camera, but when I run the start_epics file after changing st.cmd, I can connect to camera but, cannot get raw data for images and vision.
I have set  to EPICS_CA_MAX_ARRAY_BYTES to .bashrc and datasources of CSS as 1624*1234*32 and, I have set new buffer memory values for different increasing values and so, I couldn't get images. (I run aravisGigE driver on virtual CentOS 7.9 on real Linux Mint 21.04. Should I change buffer memory values and EPICS_CA_MAX_ARRAY_BYTES for Linux Mint? (This situation was not needed for Baumer cameras.))
How can I solve this problem?
I'm sending related output of start_epics.
Thanks in advance.
Best regards.
Hasan.
output of start_epics:
[cam@localhost iocAravisGigE]$ ./start_epics
< envPaths
epicsEnvSet("IOC","iocAravisGigE")
epicsEnvSet("TOP","/opt/EPICS/support/Dedektor/aravisGigE/iocs/aravisGigEIOC")
epicsEnvSet("ARAVISGIGE","/opt/EPICS/support/Dedektor/aravisGigE/iocs/aravisGigEIOC/../..")
epicsEnvSet("SUPPORT","/opt/EPICS/support")
epicsEnvSet("ASYN","/opt/EPICS/support/asyn")
epicsEnvSet("AREA_DETECTOR","/opt/EPICS/support/Dedektor")
epicsEnvSet("ADSUPPORT","/opt/EPICS/support/Dedektor/ADSupport")
epicsEnvSet("ADCORE","/opt/EPICS/support/Dedektor/ADCore")
epicsEnvSet("AUTOSAVE","/opt/EPICS/support/autosave")
epicsEnvSet("BUSY","/opt/EPICS/support/busy")
epicsEnvSet("CALC","/opt/EPICS/support/calc")
epicsEnvSet("SNCSEQ","/opt/EPICS/support/sequencer")
epicsEnvSet("SSCAN","/opt/EPICS/support/sscan")
epicsEnvSet("DEVIOCSTATS","/opt/EPICS/support/iocStats")
epicsEnvSet("EPICS_BASE","/opt/EPICS/epics-base")
errlogInit(20000)
dbLoadDatabase("/opt/EPICS/support/Dedektor/aravisGigE/iocs/aravisGigEIOC/dbd/aravisGigEApp.dbd")
aravisGigEApp_registerRecordDeviceDriver(pdbbase)
# Prefix for all records
epicsEnvSet("PREFIX", "BL:DCC:")
# The port name for the detector
epicsEnvSet("PORT",   "ARV1")
# The queue size for all plugins
epicsEnvSet("QSIZE",  "20")
# The maximim image width; used for row profiles in the NDPluginStats plugin
epicsEnvSet("XSIZE",  "1624")
# The maximim image height; used for column profiles in the NDPluginStats plugin
epicsEnvSet("YSIZE",  "1234")
# The maximum number of time series points in the NDPluginStats plugin
epicsEnvSet("NCHANS", "2048")
# The maximum number of frames buffered in the NDPluginCircularBuff plugin
epicsEnvSet("CBUFFS", "500")
# The search path for database files
epicsEnvSet("EPICS_DB_INCLUDE_PATH", "/opt/EPICS/support/Dedektor/ADCore/db")
dbLoadRecords("/opt/EPICS/support/Dedektor/aravisGigE/iocs/aravisGigEIOC/../../iocs/aravisGigEIOC/iocBoot/iocAravisGigE/Cam_Checker.db")
aravisCameraConfig("ARV1", "Allied Vision Technologies-50-0503326564")
aravisCamera: Looking for camera 'Allied Vision Technologies-50-0503326564'...
aravisCamera: Your tick frequency is 36000000
So your timestamp resolution is 27.777778 ns
aravisCamera: Done.
aravisCamera: Getting feature list...
aravisCamera: Done.
dbLoadRecords("/opt/EPICS/support/Dedektor/aravisGigE/iocs/aravisGigEIOC/../../db/AVT_Manta_G201B.template","P=BL:DCC:,R=cam1:,PORT=ARV1,ADDR=0,TIMEOUT=1")
#aravisCameraConfig("ARV2", "Baumer Optronic-0402920514")
#dbLoadRecords("$(ARAVISGIGE)/db/Baumer_VLG20M.template","P=$(PREFIX),R=cam2:,PORT=ARV2,ADDR=0,TIMEOUT=1")
asynSetTraceMask("ARV1",0,0x21)
dbLoadRecords("/opt/EPICS/support/Dedektor/aravisGigE/iocs/aravisGigEIOC/../../db/aravisCamera.template", "P=BL:DCC:,R=cam1:,PORT=ARV1,ADDR=0,TIMEOUT=1")
#asynSetTraceMask("ARV2",0,0x21)
#dbLoadRecords("$(ARAVISGIGE)/db/aravisCamera.template", "P=$(PREFIX),R=cam2:,PORT=ARV2,ADDR=0,TIMEOUT=1")
# Create a standard arrays plugin
NDStdArraysConfigure("Image1", 5, 0, "ARV1", 0, 0)
# Allow for cameras up to 2048x2048x3 for RGB
dbLoadRecords("/opt/EPICS/support/Dedektor/ADCore/db/NDStdArrays.template", "P=BL:DCC:,R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1,TYPE=Int16,FTVL=SHORT,NELEMENTS=12582912")
# Load all other plugins using commonPlugins.cmd
< /opt/EPICS/support/Dedektor/ADCore/iocBoot/commonPlugins.cmd
# This is an example file for creating plugins
# It uses the following environment variable macros
# Many of the parameters defined in this file are also in commonPlugins_settings.req so if autosave is being
# use the autosave value will replace the value passed to this file.
# $(PREFIX)      Prefix for all records
# $(PORT)        The port name for the detector.  In autosave.
# $(QSIZE)       The queue size for all plugins.  In autosave.
# $(XSIZE)       The maximum image width; used to set the maximum size for row profiles in the NDPluginStats plugin and 1-D FFT
#                   profiles in NDPluginFFT.
# $(YSIZE)       The maximum image height; used to set the maximum size for column profiles in the NDPluginStats plugin
# $(NCHANS)      The maximum number of time series points in the NDPluginStats, NDPluginROIStats, and NDPluginAttribute plugins
# $(CBUFFS)      The maximum number of frames buffered in the NDPluginCircularBuff plugin
# $(MAX_THREADS) The maximum number of threads for plugins which can run in multiple threads. Defaults to 5.
# Create a netCDF file saving plugin
NDFileNetCDFConfigure("FileNetCDF1", 20, 0, "ARV1", 0)
dbLoadRecords("NDFileNetCDF.template","P=BL:DCC:,R=netCDF1:,PORT=FileNetCDF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
# Create a TIFF file saving plugin
NDFileTIFFConfigure("FileTIFF1", 20, 0, "ARV1", 0)
dbLoadRecords("NDFileTIFF.template",  "P=BL:DCC:,R=TIFF1:,PORT=FileTIFF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
# Create a JPEG file saving plugin
NDFileJPEGConfigure("FileJPEG1", 20, 0, "ARV1", 0)
dbLoadRecords("NDFileJPEG.template",  "P=BL:DCC:,R=JPEG1:,PORT=FileJPEG1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
# Create a NeXus file saving plugin
NDFileNexusConfigure("FileNexus1", 20, 0, "ARV1", 0)
dbLoadRecords("NDFileNexus.template", "P=BL:DCC:,R=Nexus1:,PORT=FileNexus1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
# Create an HDF5 file saving plugin
NDFileHDF5Configure("FileHDF1", 20, 0, "ARV1", 0)
dbLoadRecords("NDFileHDF5.template",  "P=BL:DCC:,R=HDF1:,PORT=FileHDF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
# Create a Magick file saving plugin
#NDFileMagickConfigure("FileMagick1", $(QSIZE), 0, "$(PORT)", 0)
#dbLoadRecords("NDFileMagick.template","P=$(PREFIX),R=Magick1:,PORT=FileMagick1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
# Create 4 ROI plugins
NDROIConfigure("ROI1", 20, 0, "ARV1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDROI.template",       "P=BL:DCC:,R=ROI1:,  PORT=ROI1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
NDROIConfigure("ROI2", 20, 0, "ARV1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDROI.template",       "P=BL:DCC:,R=ROI2:,  PORT=ROI2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
NDROIConfigure("ROI3", 20, 0, "ARV1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDROI.template",       "P=BL:DCC:,R=ROI3:,  PORT=ROI3,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
NDROIConfigure("ROI4", 20, 0, "ARV1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDROI.template",       "P=BL:DCC:,R=ROI4:,  PORT=ROI4,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
# Create 8 ROIStat plugins
NDROIStatConfigure("ROISTAT1", 20, 0, "ARV1", 0, 8, 0, 0, 0, 0, 5)
dbLoadRecords("NDROIStat.template",   "P=BL:DCC:,R=ROIStat1:  ,PORT=ROISTAT1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=BL:DCC:,R=ROIStat1:1:,PORT=ROISTAT1,ADDR=0,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=BL:DCC:,R=ROIStat1:2:,PORT=ROISTAT1,ADDR=1,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=BL:DCC:,R=ROIStat1:3:,PORT=ROISTAT1,ADDR=2,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=BL:DCC:,R=ROIStat1:4:,PORT=ROISTAT1,ADDR=3,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=BL:DCC:,R=ROIStat1:5:,PORT=ROISTAT1,ADDR=4,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=BL:DCC:,R=ROIStat1:6:,PORT=ROISTAT1,ADDR=5,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=BL:DCC:,R=ROIStat1:7:,PORT=ROISTAT1,ADDR=6,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=BL:DCC:,R=ROIStat1:8:,PORT=ROISTAT1,ADDR=7,TIMEOUT=1,NCHANS=2048")
# Create a processing plugin
NDProcessConfigure("PROC1", 20, 0, "ARV1", 0, 0, 0)
dbLoadRecords("NDProcess.template",   "P=BL:DCC:,R=Proc1:,  PORT=PROC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
# Create a TIFF file plugin to read dark and flatfield images into the processing plugin
NDFileTIFFConfigure("PROC1TIFF", 20, 0, "ARV1", 0)
dbLoadRecords("NDFileTIFF.template",  "P=BL:DCC:,R=Proc1:TIFF:,PORT=PROC1TIFF,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
# Create a scatter plugin
NDScatterConfigure("SCATTER1", 20, 0, "ARV1", 0, 0, 0)
dbLoadRecords("NDScatter.template",   "P=BL:DCC:,R=Scatter1:,  PORT=SCATTER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
# Create a gather plugin with 8 ports
NDGatherConfigure("GATHER1", 20, 0, 8, 0, 0)
dbLoadRecords("NDGather.template",   "P=BL:DCC:,R=Gather1:, PORT=GATHER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
dbLoadRecords("NDGatherN.template",   "P=BL:DCC:,R=Gather1:, N=1, PORT=GATHER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
dbLoadRecords("NDGatherN.template",   "P=BL:DCC:,R=Gather1:, N=2, PORT=GATHER1,ADDR=1,TIMEOUT=1,NDARRAY_PORT=ARV1")
dbLoadRecords("NDGatherN.template",   "P=BL:DCC:,R=Gather1:, N=3, PORT=GATHER1,ADDR=2,TIMEOUT=1,NDARRAY_PORT=ARV1")
dbLoadRecords("NDGatherN.template",   "P=BL:DCC:,R=Gather1:, N=4, PORT=GATHER1,ADDR=3,TIMEOUT=1,NDARRAY_PORT=ARV1")
dbLoadRecords("NDGatherN.template",   "P=BL:DCC:,R=Gather1:, N=5, PORT=GATHER1,ADDR=4,TIMEOUT=1,NDARRAY_PORT=ARV1")
dbLoadRecords("NDGatherN.template",   "P=BL:DCC:,R=Gather1:, N=6, PORT=GATHER1,ADDR=5,TIMEOUT=1,NDARRAY_PORT=ARV1")
dbLoadRecords("NDGatherN.template",   "P=BL:DCC:,R=Gather1:, N=7, PORT=GATHER1,ADDR=6,TIMEOUT=1,NDARRAY_PORT=ARV1")
dbLoadRecords("NDGatherN.template",   "P=BL:DCC:,R=Gather1:, N=8, PORT=GATHER1,ADDR=7,TIMEOUT=1,NDARRAY_PORT=ARV1")
# Create 5 statistics plugins
NDStatsConfigure("STATS1", 20, 0, "ARV1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=BL:DCC:,R=Stats1:,  PORT=STATS1,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1624,YSIZE=1234,NCHANS=2048,NDARRAY_PORT=ARV1")
NDTimeSeriesConfigure("STATS1_TS", 20, 0, "STATS1", 1, 23)
dbLoadRecords("/opt/EPICS/support/Dedektor/ADCore/db/NDTimeSeries.template",  "P=BL:DCC:,R=Stats1:TS:, PORT=STATS1_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS1,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
NDStatsConfigure("STATS2", 20, 0, "ROI1",    0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=BL:DCC:,R=Stats2:,  PORT=STATS2,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1624,YSIZE=1234,NCHANS=2048,NDARRAY_PORT=ARV1")
NDTimeSeriesConfigure("STATS2_TS", 20, 0, "STATS2", 1, 23)
dbLoadRecords("/opt/EPICS/support/Dedektor/ADCore/db/NDTimeSeries.template",  "P=BL:DCC:,R=Stats2:TS:, PORT=STATS2_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS2,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
NDStatsConfigure("STATS3", 20, 0, "ROI2",    0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=BL:DCC:,R=Stats3:,  PORT=STATS3,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1624,YSIZE=1234,NCHANS=2048,NDARRAY_PORT=ARV1")
NDTimeSeriesConfigure("STATS3_TS", 20, 0, "STATS3", 1, 23)
dbLoadRecords("/opt/EPICS/support/Dedektor/ADCore/db/NDTimeSeries.template",  "P=BL:DCC:,R=Stats3:TS:, PORT=STATS3_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS3,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
NDStatsConfigure("STATS4", 20, 0, "ROI3",    0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=BL:DCC:,R=Stats4:,  PORT=STATS4,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1624,YSIZE=1234,NCHANS=2048,NDARRAY_PORT=ARV1")
NDTimeSeriesConfigure("STATS4_TS", 20, 0, "STATS4", 1, 23)
dbLoadRecords("/opt/EPICS/support/Dedektor/ADCore/db/NDTimeSeries.template",  "P=BL:DCC:,R=Stats4:TS:, PORT=STATS4_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS4,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
NDStatsConfigure("STATS5", 20, 0, "ROI4",    0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=BL:DCC:,R=Stats5:,  PORT=STATS5,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1624,YSIZE=1234,NCHANS=2048,NDARRAY_PORT=ARV1")
NDTimeSeriesConfigure("STATS5_TS", 20, 0, "STATS5", 1, 23)
dbLoadRecords("/opt/EPICS/support/Dedektor/ADCore/db/NDTimeSeries.template",  "P=BL:DCC:,R=Stats5:TS:, PORT=STATS5_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS5,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
# Create a transform plugin
NDTransformConfigure("TRANS1", 20, 0, "ARV1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDTransform.template", "P=BL:DCC:,R=Trans1:,  PORT=TRANS1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
# Create an overlay plugin with 8 overlays
NDOverlayConfigure("OVER1", 20, 0, "ARV1", 0, 8, 0, 0, 0, 0, 5)
dbLoadRecords("NDOverlay.template", "P=BL:DCC:,R=Over1:, PORT=OVER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
dbLoadRecords("NDOverlayN.template","P=BL:DCC:,R=Over1:1:,NAME=ROI1,   SHAPE=1,O=Over1:,XPOS=BL:DCC:ROI1:MinX_RBV,YPOS=BL:DCC:ROI1:MinY_RBV,XSIZE=BL:DCC:ROI1:SizeX_RBV,YSIZE=BL:DCC:ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=BL:DCC:,R=Over1:2:,NAME=ROI2,   SHAPE=1,O=Over1:,XPOS=BL:DCC:ROI2:MinX_RBV,YPOS=BL:DCC:ROI2:MinY_RBV,XSIZE=BL:DCC:ROI2:SizeX_RBV,YSIZE=BL:DCC:ROI2:SizeY_RBV,PORT=OVER1,ADDR=1,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=BL:DCC:,R=Over1:3:,NAME=ROI3,   SHAPE=1,O=Over1:,XPOS=BL:DCC:ROI3:MinX_RBV,YPOS=BL:DCC:ROI3:MinY_RBV,XSIZE=BL:DCC:ROI3:SizeX_RBV,YSIZE=BL:DCC:ROI3:SizeY_RBV,PORT=OVER1,ADDR=2,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=BL:DCC:,R=Over1:4:,NAME=ROI4,   SHAPE=1,O=Over1:,XPOS=BL:DCC:ROI4:MinX_RBV,YPOS=BL:DCC:ROI4:MinY_RBV,XSIZE=BL:DCC:ROI4:SizeX_RBV,YSIZE=BL:DCC:ROI4:SizeY_RBV,PORT=OVER1,ADDR=3,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=BL:DCC:,R=Over1:5:,NAME=Cursor1,SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=4,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=BL:DCC:,R=Over1:6:,NAME=Cursor2,SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=5,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=BL:DCC:,R=Over1:7:,NAME=Box1,   SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=6,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=BL:DCC:,R=Over1:8:,NAME=Box2,   SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=7,TIMEOUT=1")
# Create 2 color conversion plugins
NDColorConvertConfigure("CC1", 20, 0, "ARV1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDColorConvert.template", "P=BL:DCC:,R=CC1:,  PORT=CC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
NDColorConvertConfigure("CC2", 20, 0, "ARV1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDColorConvert.template", "P=BL:DCC:,R=CC2:,  PORT=CC2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
# Create a circular buffer plugin
NDCircularBuffConfigure("CB1", 20, 0, "ARV1", 0, 500, 0)
dbLoadRecords("NDCircularBuff.template", "P=BL:DCC:,R=CB1:,  PORT=CB1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1")
# Create an NDAttribute plugin with 8 attributes
NDAttrConfigure("ATTR1", 20, 0, "ARV1", 0, 8, 0, 0, 0)
dbLoadRecords("NDAttribute.template",  "P=BL:DCC:,R=Attr1:,    PORT=ATTR1,ADDR=0,TIMEOUT=1,NCHANS=2048,NDARRAY_PORT=ARV1")
dbLoadRecords("NDAttributeN.template", "P=BL:DCC:,R=Attr1:1:,  PORT=ATTR1,ADDR=0,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=BL:DCC:,R=Attr1:2:,  PORT=ATTR1,ADDR=1,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=BL:DCC:,R=Attr1:3:,  PORT=ATTR1,ADDR=2,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=BL:DCC:,R=Attr1:4:,  PORT=ATTR1,ADDR=3,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=BL:DCC:,R=Attr1:5:,  PORT=ATTR1,ADDR=4,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=BL:DCC:,R=Attr1:6:,  PORT=ATTR1,ADDR=5,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=BL:DCC:,R=Attr1:7:,  PORT=ATTR1,ADDR=6,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=BL:DCC:,R=Attr1:8:,  PORT=ATTR1,ADDR=7,TIMEOUT=1,NCHANS=2048")
# Create an FFT plugin
NDFFTConfigure("FFT1", 3, 0, "ARV1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDFFT.template", "P=BL:DCC:, R=FFT1:, PORT=FFT1, ADDR=0, TIMEOUT=1, NDARRAY_PORT=ARV1, NAME=FFT1, NCHANS=1624")
set_requestfile_path("./")
set_requestfile_path("/opt/EPICS/support/Dedektor/ADCore/ADApp/Db")
set_requestfile_path("/opt/EPICS/support/Dedektor/ADCore/iocBoot")
set_savefile_path("./autosave")
set_pass0_restoreFile("auto_settings.sav")
set_pass1_restoreFile("auto_settings.sav")
save_restoreSet_status_prefix("BL:DCC:")
dbLoadRecords("/opt/EPICS/support/autosave/asApp/Db/save_restoreStatus.db", "P=BL:DCC:")
# Optional: load NDPluginPva plugin
#NDPvaConfigure("PVA1", $(QSIZE), 0, "$(PORT)", 0, $(PREFIX)Pva1:Image, 0, 0, 0)
#dbLoadRecords("NDPva.template",  "P=$(PREFIX),R=Pva1:, PORT=PVA1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
# Must start PVA server if this is enabled
#startPVAServer
# Optional: load NDPluginEdge plugin
#NDEdgeConfigure("EDGE1", $(QSIZE), 0, "$(PORT)", 0, 0, 0, 0)
#dbLoadRecords("$(ADPLUGINEDGE)/db/NDEdge.template",  "P=$(PREFIX),R=Edge1:, PORT=EDGE1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
#set_requestfile_path("$(ADPLUGINEDGE)/edgeApp/Db")
# Optional: load scan records
#dbLoadRecords("$(SSCAN)/sscanApp/Db/scan.db", "P=$(PREFIX),MAXPTS1=2000,MAXPTS2=200,MAXPTS3=20,MAXPTS4=10,MAXPTSH=10")
#set_requestfile_path("$(SSCAN)/sscanApp/Db")
# Optional: load sseq record for acquisition sequence
#dbLoadRecords("$(CALC)/calcApp/Db/sseqRecord.db", "P=$(PREFIX), S=AcquireSequence")
#set_requestfile_path("$(CALC)/calcApp/Db")
# Optional: load devIocStats records (requires DEVIOCSTATS module)
#dbLoadRecords("$(DEVIOCSTATS)/db/iocAdminSoft.db", "IOC=$(PREFIX)")
# Optional: load alive record (requires ALIVE module)
#dbLoadRecords("$(ALIVE)/aliveApp/Db/alive.db", "P=$(PREFIX),RHOST=192.168.1.254")
macLib: macro ADPILATUS is undefined (expanding string set_requestfile_path("$(ADPILATUS)/prosilicaApp/Db"))
#asynSetTraceMask("$(PORT)",0,255)
#asynSetTraceMask("$(PORT)",0,3)
iocInit()
Starting iocInit
## EPICS R3.15.8
## EPICS Base built Aug 24 2021
reboot_restore: entry for file 'auto_settings.sav'
reboot_restore: Found filename 'auto_settings.sav' in restoreFileList.
*** restoring from './autosave/auto_settings.sav' at initHookState 6 (before record/device init) ***
reboot_restore: done with file 'auto_settings.sav'
2021/10/15 10:26:42.552 asynPortDriver:drvUserCreate: addr=0, cannot find parameter CURSOR_VAL
BL:DCC:Stats1:CursorVal devAsynFloat64::initCommon drvUserCreate
BL:DCC:Stats2:CursorVal devAsynFloat64::initCommon drvUserCreate
BL:DCC:Stats3:CursorVal devAsynFloat64::initCommon drvUserCreate
2021/10/15 10:26:42.553 asynPortDriver:drvUserCreate: addr=0, cannot find parameter CURSOR_VAL
BL:DCC:Stats4:CursorVal devAsynFloat64::initCommon drvUserCreate
BL:DCC:Stats5:CursorVal devAsynFloat64::initCommon drvUserCreate
aravisCamera: Adding feature DeviceVendorName with value: Allied Vision Technologies
aravisCamera: Adding feature DeviceModelName with value: Manta_G-201B
aravisCamera: Adding feature DeviceFirmwareVersion with value: 00.01.44.04
aravisCamera: Adding feature DeviceID with value: 50-0503326564
aravisCamera: Adding feature DevicePartNumber with value: E0020008
aravisCamera: Adding feature ModelName with value: Manta_G-201B
*** restoring from './autosave/auto_settings.sav' at initHookState 7 (after record/device init) ***
2021/10/15 10:26:43.916 NDPluginDriver::writeInt32 cannot do ProcessPlugin, no input array cached
2021/10/15 10:26:43.916 NDPluginDriver::writeInt32 ERROR, status=3, function=66, value=1, connectedToArrayPort_=1
2021/10/15 10:26:43.918 NDPluginDriver::writeInt32 cannot do ProcessPlugin, no input array cached
2021/10/15 10:26:43.918 NDPluginDriver::writeInt32 ERROR, status=3, function=66, value=1, connectedToArrayPort_=1
2021/10/15 10:26:43.919 NDPluginDriver::writeInt32 cannot do ProcessPlugin, no input array cached
2021/10/15 10:26:43.919 NDPluginDriver::writeInt32 ERROR, status=3, function=66, value=1, connectedToArrayPort_=1
2021/10/15 10:26:43.920 NDPluginDriver::writeInt32 cannot do ProcessPlugin, no input array cached
2021/10/15 10:26:43.920 NDPluginDriver::writeInt32 ERROR, status=3, function=66, value=1, connectedToArrayPort_=1
2021/10/15 10:26:43.922 NDPluginDriver::writeInt32 cannot do ProcessPlugin, no input array cached
2021/10/15 10:26:43.922 NDPluginDriver::writeInt32 ERROR, status=3, function=66, value=1, connectedToArrayPort_=1
# save things every thirty seconds
create_monitor_set("auto_settings.req", 30,"P=BL:DCC:")
save_restore:readReqFile: unable to open file aravisCamera_settings.req. Exiting.
save_restore:readReqFile: unable to open file sseq_settings.req. Exiting.
create_monitor_set("commonPlugin_settings.req",30,"P=BL:DCC:")
commonPlugin_settings.sav: 1070 of 1070 PV's connected
auto_settings.sav: 1086 of 1086 PV's connected
epics>Bad Frame Status: Timeout
Bad Frame Status: Timeout, 10 msgs suppressed
Hasan Sansar
aravisGigE driver for AVT Manta camera Hasan SANSAR via Tech-talk
Prev: aravisGigE driver for AVT Manta camera Hasan SANSAR via Tech-talk
Next: Java & CA Pavel Cheblakov via Tech-talk
Next: Re: aravisGigE driver for AVT Manta camera Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
