Hi SeokHoMoon,
First, please use copy and paste to put the errors in your e-mail, not screen captures.
> I try to use the latest version of asyn but some error occured. I think there is some compatibility issue in my environment so I used the 4-26 version.
Please send the exact error message when you use the new version of asyn.
What version of libusb are you using?
Sent: Tuesday, October 19, 2021 3:45 AM
To: Mark Rivers; [email protected]
Cc: [email protected]
Subject: Can't get device capability and Can't clear buffers
First of all, I'm sorry that sending the reply with different email address.
There is some issue at my university mail system so I send the mail with gmail.
Thanks for your support, Mark Rivers and Eric Norum. However, I faced some other issue with usbtmc.
After I saw the Eric's fixed code. I change the drcAsynUSBTMC.c file like Eric but I saw the new message like below
The version of asyn and base is 4-26, 3.14.12.5 which is same with past.
But when I check the drcAsynUSBTMC.c file of asyn-4.26 and latest version, there was no difference so I think it is not a problem.
1. Centos 7 environment (libusb_ver=0.1.4)
1. Rasberrypi3 environment (libusb_ver=1.0)
In different environment, the epics shows the same message.
To check the usb cable and the dg812 equipment, I communicate with dg812 by using Ultra Sigma(Program of RIGOL) and Ni-Max test panel but there were no error.
Best Regards
SeokHoMoon
- Can't get device capability and Can't clear buffers 문석호 via Tech-talk
Re: aravisGigE driver for AVT Manta camera Palaha, Arvinder (DLSLtd, RAL, LSCI) via Tech-talk
RE: ADAravis multiple image mode fail for Basler raL12288-8gm Mark Rivers via Tech-talk
<2021>
2025
2026
Re: Tech-talk Digest, Vol 15, Issue 547 Katie Matusik via Tech-talk
<2021>
2025
2026
