Hi all, I met a question about stream module.
Centos 8(64), base-7.0.6.1, stream [...]
And I got the error when make : ( "libpcre.a', needed by 'libstream.so'." )
If you want to compile StreamDevice with pcre support, you need to install the pcre package on your system first, then tell stream where the library is located.
Cheers, ~Ralph
- stream install error 网易邮件中心 via Tech-talk
motor module make error 网易邮件中心 via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
