Hi all, I use centos8, base 7.0.6.1, motor ( https://github.com/epics-modules/motor ), seq-2.2.6, and some other module from https://github.com/epics-modules/. I got the error message. --------------------Error---------------------------------------- make -C ./modules install make[1]: Entering directory '/home/liangyx/synApps/support/motor-master/modules' make -C ./motorOms install make[2]: Entering directory '/home/liangyx/synApps/support/motor-master/modules/motorOms' make -C ./configure install make[3]: Entering directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/configure' make -C O.linux-x86_64 -f ../Makefile TOP=../.. \ T_A=linux-x86_64 install make[4]: Entering directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/configure/O.linux-x86_64' perl -CSD /home/liangyx/base-7.0.6.1/bin/linux-x86_64/convertRelease.pl checkRelease make[4]: Leaving directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/configure/O.linux-x86_64' make[3]: Leaving directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/configure' make -C ./omsApp install make[3]: Entering directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/omsApp' make -C ./src install make[4]: Entering directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/omsApp/src' make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \ T_A=linux-x86_64 install make[5]: Entering directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/omsApp/src/O.linux-x86_64' /usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/home/liangyx/synApps/support/motor-master/include/compiler/gcc -I/home/liangyx/synApps/support/motor-master/include/os/Linux -I/home/liangyx/synApps/support/motor-master/include -I/home/liangyx/synApps/support/motor-master/include -I/home/liangyx/synApps/support/asyn-master/include -I/home/liangyx/synApps/support/seq-2.2.6/include -I/home/liangyx/synApps/support/busy-master/include -I/home/liangyx/synApps/support/ipac-master/include -I/home/liangyx/base-7.0.6.1/include/compiler/gcc -I/home/liangyx/base-7.0.6.1/include/os/Linux -I/home/liangyx/base-7.0.6.1/include -c ../drvOmsPC68.cc In file included from /home/liangyx/base-7.0.6.1/include/dbAccess.h:20, from ../drvOmsPC68.cc:72: /home/liangyx/base-7.0.6.1/include/dbBase.h:164:22: warning: ‘rset’ is deprecated [-Wdeprecated-declarations] rset *prset; ^~~~~ In file included from /home/liangyx/base-7.0.6.1/include/dbBase.h:22, from /home/liangyx/base-7.0.6.1/include/dbAccess.h:20, from ../drvOmsPC68.cc:72: /home/liangyx/base-7.0.6.1/include/recSup.h:89:21: note: declared here typedef struct rset rset EPICS_DEPRECATED; ^~~~ In file included from /home/liangyx/base-7.0.6.1/include/dbAccess.h:24, from ../drvOmsPC68.cc:72: /home/liangyx/base-7.0.6.1/include/dbAccessDefs.h:210:55: warning: ‘rset’ is deprecated [-Wdeprecated-declarations] DBCORE_API rset * dbGetRset(const struct dbAddr *paddr); ^ In file included from /home/liangyx/base-7.0.6.1/include/dbBase.h:22, from /home/liangyx/base-7.0.6.1/include/dbAccess.h:20, from ../drvOmsPC68.cc:72: /home/liangyx/base-7.0.6.1/include/recSup.h:89:21: note: declared here typedef struct rset rset EPICS_DEPRECATED; ^~~~ ../drvOmsPC68.cc:110:66: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings] static char *oms_axis[] = {"X", "Y", "Z", "T", "U", "V", "R", "S"}; ^ ../drvOmsPC68.cc:110:66: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings] ../drvOmsPC68.cc:110:66: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings] ../drvOmsPC68.cc:110:66: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings] ../drvOmsPC68.cc:110:66: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings] ../drvOmsPC68.cc:110:66: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings] ../drvOmsPC68.cc:110:66: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings] ../drvOmsPC68.cc:110:66: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings] ../drvOmsPC68.cc:148:1: error: invalid conversion from ‘RTN_STATUS (*)(int, const char*, char*)’ {aka ‘RTN_VALUES (*)(int, const char*, char*)’} to ‘RTN_STATUS (*)(int, const char*, const char*)’ {aka ‘RTN_VALUES (*)(int, const char*, const char*)’} [-fpermissive] }; ^ ../drvOmsPC68.cc:148:1: error: invalid conversion from ‘char**’ to ‘const char**’ [-fpermissive] ../drvOmsPC68.cc: In function ‘void asynCallback(void*, asynUser*, char*, size_t, int)’: ../drvOmsPC68.cc:687:7: warning: suggest explicit braces to avoid ambiguous ‘else’ [-Wdangling-else] if( stat & STAT_DONE ) ^ make[5]: *** [/home/liangyx/base-7.0.6.1/configure/RULES_BUILD:263: drvOmsPC68.o] Error 1 make[5]: Leaving directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/omsApp/src/O.linux-x86_64' make[4]: *** [/home/liangyx/base-7.0.6.1/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2 make[4]: Leaving directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/omsApp/src' make[3]: *** [/home/liangyx/base-7.0.6.1/configure/RULES_DIRS:85: src.install] Error 2 make[3]: Leaving directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/omsApp' make[2]: *** [/home/liangyx/base-7.0.6.1/configure/RULES_DIRS:85: omsApp.install] Error 2 make[2]: Leaving directory '/home/liangyx/synApps/support/motor-master/modules/motorOms' make[1]: *** [/home/liangyx/base-7.0.6.1/configure/RULES_DIRS:85: motorOms.install] Error 2 make[1]: Leaving directory '/home/liangyx/synApps/support/motor-master/modules' make: *** [/home/liangyx/base-7.0.6.1/configure/RULES_DIRS:85: modules.install] Error 2 --------------------End---------------------------------------- I could not find the problem Could someone give me some advice. Regards, Liang
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
