Subject: QuadEM operation with parameters "Queued"
From: Iain Marcuson via Tech-talk <[email protected]>
Date: Thu, 21 Oct 2021 13:52:33 +0000
I am working on writing a new IOC for QuadEM device, and the IOC mostly works.  The IOC talks over TCP via asyn to a middle software layer that talks to the hardware.  The middle layer can send unsolicited messages to EPICS, so I implemented polling by having a record scan once a second and read the port.  Sometimes, however, I get a case where EPICS seems to be queueing writes, so I would get
Change parameter A -> No message send
Change parameter B -> Send A
Change parameter C -> Send B
All writes, which includes the 1 Hz record mentioned above, write to the same shared buffer that is then sent, so might there be contention there?
Thank you,
Iain Marcuson
Software Engineer, Sydor Technologies
585.278.1168 | www.SydorTechnologies.com
Skype: [email protected]
This message has been scanned for malware by Forcepoint. www.forcepoint.com
Re: QuadEM operation with parameters "Queued" Mark Rivers via Tech-talk
Prev: motor module make error 网易邮件中心 via Tech-talk
Next: Re: QuadEM operation with parameters "Queued" Mark Rivers via Tech-talk
Prev: Re: Re:RE: motor module make error Mark Rivers via Tech-talk
