Subject: Re: Re:RE: motor module make error
To: 网易邮件中心 <[email protected]>
Date: Fri, 22 Oct 2021 13:26:18 +0000
Hi Liang,
The error you are getting was fixed in this commit in 2019:
https://github.com/epics-motor/motorOms/commit/261383e11f8ce8fb3dad4e8c531e13a73405874c#diff-da9f8aee7822265d97f40e2bfa61fab84ae3828cda87aa2458130bbc2bf29292
Sent: Friday, October 22, 2021 5:10 AM
To: Mark Rivers
Cc: tech-talk; [email protected]; [email protected]
Subject: Re:RE: motor module make error
Hi all,
    Thank you for your kind answer.
     It was good for centos 8,  base-7.0.6.1 and motor-master.   Sorry, I described the question wrongly.
    It was good motor-master.
    But i found that the file ( motor-master/module/)  was empty.
    So I copied "motorAMCI,motor* files" from synApps_6_1  to motor-master/module.
    Then the error came out.
    Today, I unzip the motor-master.zip and make, it was good.
     But how should i do it, to add the motorAMCI,motorKohzu in /module/ file?
Liang
$ gcc --versiongcc (GCC) 8.4.1 20200928 (Red Hat 8.4.1-1)
Copyright (C) 2018 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
$ uname -r
4.18.0-305.19.1.el8_4.x86_64
At 2021-10-22 06:24:26, "Mark Rivers" <[email protected]> wrote:
Hi Liang,
I just built that file on Centos 8 using gcc 8.4.1-1.  It builds fine for me.
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/corvette/home/epics/devel/motor-7-0/include/compiler/gcc -I/corvette/home/epics/devel/motor-7-0/include/os/Linux -I/corvette/home/epics/devel/motor-7-0/include   -I/corvette/home/epics/devel/motor-7-0/include   -I/corvette/home/epics/devel/asyn-4-42/include   -I/corvette/home/epics/devel/seq-2-2-5/include   -I/corvette/home/epics/devel/busy-1-7-2/include   -I/corvette/home/epics/devel/ipac-2-15/include -I/corvette/usr/local/epics-devel/base-7.0.5/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.5/include/os/Linux -I/corvette/usr/local/epics-devel/base-7.0.5/include           -c ../drvOmsPC68.cc
In file included from /corvette/usr/local/epics-devel/base-7.0.5/include/dbAccess.h:20,
                 from ../drvOmsPC68.cc:72:
/corvette/usr/local/epics-devel/base-7.0.5/include/dbBase.h:164:22: warning: ‘rset’ is deprecated [-Wdeprecated-declarations]
     rset            *prset;
In file included from /corvette/usr/local/epics-devel/base-7.0.5/include/dbBase.h:22,
/corvette/usr/local/epics-devel/base-7.0.5/include/recSup.h:89:21: note: declared here
typedef struct rset rset EPICS_DEPRECATED;
In file included from /corvette/usr/local/epics-devel/base-7.0.5/include/dbAccess.h:24,
/corvette/usr/local/epics-devel/base-7.0.5/include/dbAccessDefs.h:211:59: warning: ‘rset’ is deprecated [-Wdeprecated-declarations]
epicsShareFunc rset * dbGetRset(const struct dbAddr *paddr);
../drvOmsPC68.cc: In function ‘int omsGet(int, char*)’:
../drvOmsPC68.cc:660:17: warning: variable ‘status’ set but not used [-Wunused-but-set-variable]
     asynStatus  status;
../drvOmsPC68.cc: In function ‘void asynCallback(void*, asynUser*, char*, size_t, int)’:
../drvOmsPC68.cc:687:7: warning: suggest explicit braces to avoid ambiguous ‘else’ [-Wdangling-else]
     if( stat & STAT_DONE )
What version of gcc are you using?  (gcc ?version).
From: Tech-talk <[email protected]> On Behalf Of ?????? via Tech-talk
Sent: Wednesday, October 20, 2021 10:23 PM
To: tech-talk <[email protected]>
Subject: motor module make error
Hi all,
     I use centos8, base 7.0.6.1, motor ( https://github.com/epics-modules/motor ), seq-2.2.6, and some other module from https://github.com/epics-modules/.<https://github.com/epics-modules/>
    I got the error message.
--------------------Error----------------------------------------
make -C ./modules install
make[1]: Entering directory '/home/liangyx/synApps/support/motor-master/modules'
make -C ./motorOms install
make[2]: Entering directory '/home/liangyx/synApps/support/motor-master/modules/motorOms'
make -C ./configure install
make[3]: Entering directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[4]: Entering directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/configure/O.linux-x86_64'
perl -CSD /home/liangyx/base-7.0.6.1/bin/linux-x86_64/convertRelease.pl checkRelease
make[4]: Leaving directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/configure/O.linux-x86_64'
make[3]: Leaving directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/configure'
make -C ./omsApp install
make[3]: Entering directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/omsApp'
make -C ./src install
make[4]: Entering directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/omsApp/src'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[5]: Entering directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/omsApp/src/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/home/liangyx/synApps/support/motor-master/include/compiler/gcc -I/home/liangyx/synApps/support/motor-master/include/os/Linux -I/home/liangyx/synApps/support/motor-master/include   -I/home/liangyx/synApps/support/motor-master/include   -I/home/liangyx/synApps/support/asyn-master/include   -I/home/liangyx/synApps/support/seq-2.2.6/include   -I/home/liangyx/synApps/support/busy-master/include   -I/home/liangyx/synApps/support/ipac-master/include -I/home/liangyx/base-7.0.6.1/include/compiler/gcc -I/home/liangyx/base-7.0.6.1/include/os/Linux -I/home/liangyx/base-7.0.6.1/include           -c ../drvOmsPC68.cc
In file included from /home/liangyx/base-7.0.6.1/include/dbAccess.h:20,
/home/liangyx/base-7.0.6.1/include/dbBase.h:164:22: warning: ‘rset’ is deprecated [-Wdeprecated-declarations]
     rset            *prset;
In file included from /home/liangyx/base-7.0.6.1/include/dbBase.h:22,
/home/liangyx/base-7.0.6.1/include/recSup.h:89:21: note: declared here
In file included from /home/liangyx/base-7.0.6.1/include/dbAccess.h:24,
/home/liangyx/base-7.0.6.1/include/dbAccessDefs.h:210:55: warning: ‘rset’ is deprecated [-Wdeprecated-declarations]
 DBCORE_API rset * dbGetRset(const struct dbAddr *paddr);
../drvOmsPC68.cc:110:66: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
 static char *oms_axis[] = {"X", "Y", "Z", "T", "U", "V", "R", "S"};
../drvOmsPC68.cc:148:1: error: invalid conversion from ‘RTN_STATUS (*)(int, const char*, char*)’ {aka ‘RTN_VALUES (*)(int, const char*, char*)’} to ‘RTN_STATUS (*)(int, const char*, const char*)’ {aka ‘RTN_VALUES (*)(int, const char*, const char*)’} [-fpermissive]
../drvOmsPC68.cc:148:1: error: invalid conversion from ‘char**’ to ‘const char**’ [-fpermissive]
make[5]: *** [/home/liangyx/base-7.0.6.1/configure/RULES_BUILD:263: drvOmsPC68.o] Error 1
make[5]: Leaving directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/omsApp/src/O.linux-x86_64'
make[4]: *** [/home/liangyx/base-7.0.6.1/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[4]: Leaving directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/omsApp/src'
make[3]: *** [/home/liangyx/base-7.0.6.1/configure/RULES_DIRS:85: src.install] Error 2
make[3]: Leaving directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/omsApp'
make[2]: *** [/home/liangyx/base-7.0.6.1/configure/RULES_DIRS:85: omsApp.install] Error 2
make[2]: Leaving directory '/home/liangyx/synApps/support/motor-master/modules/motorOms'
make[1]: *** [/home/liangyx/base-7.0.6.1/configure/RULES_DIRS:85: motorOms.install] Error 2
make[1]: Leaving directory '/home/liangyx/synApps/support/motor-master/modules'
make: *** [/home/liangyx/base-7.0.6.1/configure/RULES_DIRS:85: modules.install] Error 2
--------------------End----------------------------------------
I could not find the problem
Could someone give me some advice.
Liang
motor module make error 网易邮件中心 via Tech-talk
Re:RE: motor module make error 网易邮件中心 via Tech-talk
Prev: Data Browser (phoebus) auto data fetching from an Archiver Appliance BENEDETTI Florian via Tech-talk
Next: Re: [EXTERNAL] Data Browser (phoebus) auto data fetching from an Archiver Appliance Hartman, Steven via Tech-talk
Prev: Re: motor module make error Torsten Bögershausen via Tech-talk
Next: QuadEM operation with parameters "Queued" Iain Marcuson via Tech-talk
