Subject: Re: motor module make error
From: Torsten Bögershausen via Tech-talk <[email protected]>
To: 网易邮件中心 <[email protected]>, Mark Rivers <[email protected]>
Date: Fri, 22 Oct 2021 12:45:49 +0200
Hej Liang,
how did you clone the motor module?
All (nearly all) files under the modules/ directory are now handled
as git submodules.
Using
git clone --recursive 	https://github.com/epics-modules/motor.git
does what you need.
Or, if you have forgotten the "--recursive":
cd modules
git submodules init
git submodules update
will get what you want.
On 10/22/21 12:10 PM, 网易邮件中心 via Tech-talk wrote:
Hi all,
     Thank you for your kind answer.
     It was good for centos 8,  base-7.0.6.1 and motor-master.   Sorry, I described the question wrongly.
     It was good motor-master.
     But i found that the file ( motor-master/module/)  was empty.
    So I copied "motorAMCI,motor* files" from synApps_6_1  to motor-master/module.
     Then the error came out.
     Today, I unzip the motor-master.zip and make, it was good.
     But how should i do it, to add the motorAMCI,motorKohzu in /module/ file?
Liang
$ gcc --versiongcc (GCC) 8.4.1 20200928 (Red Hat 8.4.1-1)
Copyright (C) 2018 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
$ uname -r
4.18.0-305.19.1.el8_4.x86_64
At 2021-10-22 06:24:26, "Mark Rivers" <[email protected]> wrote:
    Hi Liang,
    I just built that file on Centos 8 using gcc 8.4.1-1.  It builds
    fine for me.
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64
    -fPIC -I. -I../O.Common -I. -I. -I..
    -I/corvette/home/epics/devel/motor-7-0/include/compiler/gcc
    -I/corvette/home/epics/devel/motor-7-0/include/os/Linux
-I/corvette/home/epics/devel/motor-7-0/include -I/corvette/home/epics/devel/motor-7-0/include -I/corvette/home/epics/devel/asyn-4-42/include -I/corvette/home/epics/devel/seq-2-2-5/include -I/corvette/home/epics/devel/busy-1-7-2/include -I/corvette/home/epics/devel/ipac-2-15/include
    -I/corvette/usr/local/epics-devel/base-7.0.5/include/compiler/gcc
    -I/corvette/usr/local/epics-devel/base-7.0.5/include/os/Linux
    -I/corvette/usr/local/epics-devel/base-7.0.5/include           -c
    ../drvOmsPC68.cc
    In file included from
    /corvette/usr/local/epics-devel/base-7.0.5/include/dbAccess.h:20,
                      from ../drvOmsPC68.cc:72:
    /corvette/usr/local/epics-devel/base-7.0.5/include/dbBase.h:164:22:
    warning: ‘rset’ is deprecated [-Wdeprecated-declarations]
          rset            *prset;
    /corvette/usr/local/epics-devel/base-7.0.5/include/dbBase.h:22,
                      from
    /corvette/usr/local/epics-devel/base-7.0.5/include/recSup.h:89:21:
    note: declared here
    typedef struct rset rset EPICS_DEPRECATED;
    /corvette/usr/local/epics-devel/base-7.0.5/include/dbAccess.h:24,
    /corvette/usr/local/epics-devel/base-7.0.5/include/dbAccessDefs.h:211:59:
    epicsShareFunc rset * dbGetRset(const struct dbAddr *paddr);
                      from
    note: declared here
    ../drvOmsPC68.cc: In function ‘int omsGet(int, char*)’:
    ../drvOmsPC68.cc:660:17: warning: variable ‘status’ set but not used
    [-Wunused-but-set-variable]
          asynStatus  status;
    ../drvOmsPC68.cc: In function ‘void asynCallback(void*, asynUser*,
    char*, size_t, int)’:
    ../drvOmsPC68.cc:687:7: warning: suggest explicit braces to avoid
    ambiguous ‘else’ [-Wdangling-else]
          if( stat & STAT_DONE )
    What version of gcc are you using?  (gcc –version).
    *?????? via Tech-talk
    *Sent:* Wednesday, October 20, 2021 10:23 PM
    *To:* tech-talk <[email protected]>
    *Subject:* motor module make error
    Hi all,
          I use centos8, base 7.0.6.1, motor (
    <https://github.com/epics-modules/motor> ), seq-2.2.6, and some
    other module from https://github.com/epics-modules/.
    <https://github.com/epics-modules/>
         I got the error message.
    --------------------Error----------------------------------------
    make -C ./modules install
    make[1]: Entering directory
    '/home/liangyx/synApps/support/motor-master/modules'
    make -C ./motorOms install
    make[2]: Entering directory
    '/home/liangyx/synApps/support/motor-master/modules/motorOms'
    make -C ./configure install
    make[3]: Entering directory
    '/home/liangyx/synApps/support/motor-master/modules/motorOms/configure'
    make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
         T_A=linux-x86_64 install
    make[4]: Entering directory
    '/home/liangyx/synApps/support/motor-master/modules/motorOms/configure/O.linux-x86_64'
    perl -CSD
    /home/liangyx/base-7.0.6.1/bin/linux-x86_64/convertRelease.pl
    checkRelease
    make[4]: Leaving directory
    make[3]: Leaving directory
    make -C ./omsApp install
    '/home/liangyx/synApps/support/motor-master/modules/motorOms/omsApp'
    make -C ./src install
    '/home/liangyx/synApps/support/motor-master/modules/motorOms/omsApp/src'
    make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
    make[5]: Entering directory
    '/home/liangyx/synApps/support/motor-master/modules/motorOms/omsApp/src/O.linux-x86_64'
    -I/home/liangyx/synApps/support/motor-master/include/compiler/gcc
    -I/home/liangyx/synApps/support/motor-master/include/os/Linux
-I/home/liangyx/synApps/support/motor-master/include -I/home/liangyx/synApps/support/motor-master/include -I/home/liangyx/synApps/support/asyn-master/include -I/home/liangyx/synApps/support/seq-2.2.6/include -I/home/liangyx/synApps/support/busy-master/include
    -I/home/liangyx/synApps/support/ipac-master/include
    -I/home/liangyx/base-7.0.6.1/include/compiler/gcc
    -I/home/liangyx/base-7.0.6.1/include/os/Linux
    -I/home/liangyx/base-7.0.6.1/include           -c ../drvOmsPC68.cc
    In file included from /home/liangyx/base-7.0.6.1/include/dbAccess.h:20,
    /home/liangyx/base-7.0.6.1/include/dbBase.h:164:22: warning: ‘rset’
          rset            *prset;
    In file included from /home/liangyx/base-7.0.6.1/include/dbBase.h:22,
    /home/liangyx/base-7.0.6.1/include/recSup.h:89:21: note: declared here
    In file included from /home/liangyx/base-7.0.6.1/include/dbAccess.h:24,
    /home/liangyx/base-7.0.6.1/include/dbAccessDefs.h:210:55: warning:
      DBCORE_API rset * dbGetRset(const struct dbAddr *paddr);
    ../drvOmsPC68.cc:110:66: warning: ISO C++ forbids converting a
    string constant to ‘char*’ [-Wwrite-strings]
      static char *oms_axis[] = {"X", "Y", "Z", "T", "U", "V", "R", "S"};
    ../drvOmsPC68.cc:148:1: error: invalid conversion from ‘RTN_STATUS
    (*)(int, const char*, char*)’ {aka ‘RTN_VALUES (*)(int, const char*,
    char*)’} to ‘RTN_STATUS (*)(int, const char*, const char*)’ {aka
    ‘RTN_VALUES (*)(int, const char*, const char*)’} [-fpermissive]
    ../drvOmsPC68.cc:148:1: error: invalid conversion from ‘char**’ to
    ‘const char**’ [-fpermissive]
    make[5]: *** [/home/liangyx/base-7.0.6.1/configure/RULES_BUILD:263:
    drvOmsPC68.o] Error 1
    make[5]: Leaving directory
    make[4]: *** [/home/liangyx/base-7.0.6.1/configure/RULES_ARCHS:58:
    install.linux-x86_64] Error 2
    make[3]: *** [/home/liangyx/base-7.0.6.1/configure/RULES_DIRS:85:
    src.install] Error 2
    make[2]: *** [/home/liangyx/base-7.0.6.1/configure/RULES_DIRS:85:
    omsApp.install] Error 2
    make[2]: Leaving directory
    make[1]: *** [/home/liangyx/base-7.0.6.1/configure/RULES_DIRS:85:
    motorOms.install] Error 2
    make[1]: Leaving directory
    make: *** [/home/liangyx/base-7.0.6.1/configure/RULES_DIRS:85:
    modules.install] Error 2
    --------------------End----------------------------------------
    I could not find the problem
    Could someone give me some advice.
    Liang
motor module make error 网易邮件中心 via Tech-talk
Re:RE: motor module make error 网易邮件中心 via Tech-talk
Prev: Re:RE: motor module make error 网易邮件中心 via Tech-talk
Next: Data Browser (phoebus) auto data fetching from an Archiver Appliance BENEDETTI Florian via Tech-talk
Next: Re: Re:RE: motor module make error Mark Rivers via Tech-talk
