Subject: RE: undefine variable in RELEASE.local
From: "Pearson, Matthew R. via Tech-talk" <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 26 Oct 2021 21:13:23 +0000
Hi Andrew,
That patch does indeed fix it, thanks!
I should have mentioned that I was using base 7.0.6, and I didn’t realize I was using a new feature from 7.0.5, and I wasn’t too familiar with how the RELEASE files are parsed, but it makes sense now.
Cheers,
Matt
Sent: Tuesday, October 26, 2021 4:22 PM
To: Pearson, Matthew R. <[email protected]>
Subject: [EXTERNAL] Re: undefine variable in RELEASE.local
Hi Matt,
On Oct 26, 2021, at 9:26 AM, Pearson, Matthew R. via Tech-talk <[email protected]> wrote:
undefine SNCSEQ
EPICS_BASE=/home/controls/common/base/main
Although this causes errors like these when building asyn:
make[2]: Entering directory '/home/controls/common/asyn/main/iocBoot/ioctest'
perl -CSD /home/controls/common/base/main/bin/linux-x86_64/convertRelease.pl -t /home/controls/common/asyn/main envPaths
Use of uninitialized value $iocpath in substitution (s///) at /home/controls/common/base/main/bin/linux-x86_64/convertRelease.pl line 220.
Use of uninitialized value $path in -d at /home/controls/common/base/main/bin/linux-x86_64/convertRelease.pl line 221.
Oops! This patch to Base should fix the problem, please try it:
diff --git a/src/tools/EPICS/Release.pm b/src/tools/EPICS/Release.pm
index 7caa6f4c6..e6aaf1e0c 100644
--- a/src/tools/EPICS/Release.pm
+++ b/src/tools/EPICS/Release.pm
@@ -67,6 +67,7 @@ sub readRelease {
         my ($uvar) = m/^ undefine \s+ ($MVAR)/x;
         if ($uvar ne '') {
             delete $Rmacros->{$uvar};
+            @$Rapps = grep($_ ne $uvar, @$Rapps);
             next;
Do you know what's causing these errors? I suppose the script just isn't silently dealing with the 'undefine' syntax?
Yup, and I evidently didn’t test the code properly when I added support for undefine (in Base 7.0.5 I believe).
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: undefine variable in RELEASE.local Johnson, Andrew N. via Tech-talk
undefine variable in RELEASE.local Pearson, Matthew R. via Tech-talk
Prev: Re: undefine variable in RELEASE.local Johnson, Andrew N. via Tech-talk
Next: Re: undefine variable in RELEASE.local Johnson, Andrew N. via Tech-talk
