Subject: Re: IOC in Docker not responding to caget from another host
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Paduan Donadio, Marcio" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 28 Oct 2021 21:48:13 -0700
On 10/28/21 3:59 PM, Paduan Donadio, Marcio via Tech-talk wrote:
> $ sudo iptables -L -t nat
Use 'sudo iptables-save' to print all tables, not just 'nat'.
Also check both host and container.
> DNAT       udp  --  anywhere             <server name>  udp dpt:5064 to:134.79.219.255
It might be simpler while troubleshooting to remove any *NAT or
MASQUERADE targets and test only the connection between the
container and the host.
fyi. one quick check for firewall is to connect to the TCP port
of a CA or PVA server with 'telnet'.  Seeing a TCP connection
establish is sufficient.  Also, PVA, and newer CA, servers will
send a message on connection.  eg.
> $ telnet localhost 5075
> Trying 127.0.0.1...
> Connected to localhost.
> Escape character is '^]'.
> �A�@    anonymousca^]
> telnet> q
> Connection closed.
Re: IOC in Docker not responding to caget from another host Paduan Donadio, Marcio via Tech-talk
Re: IOC in Docker not responding to caget from another host Florian Feldbauer via Tech-talk
Re: IOC in Docker not responding to caget from another host Lucas Russo via Tech-talk
Prev: Re: IOC in Docker not responding to caget from another host Hu, Yong via Tech-talk
Next: Does camonitor update when the record processes? Wang, Andrew via Tech-talk
Next: Re: IOC in Docker not responding to caget from another host Paduan Donadio, Marcio via Tech-talk
