Subject: Does camonitor update when the record processes?
From: "Wang, Andrew via Tech-talk" <[email protected]>
Date: Fri, 29 Oct 2021 07:19:27 +0000
Hi all,
Quick question. So I have noticed that when we run camonitor for a record called "foo", it initially doesn't show a time stamp. When I then do caput foo.PROC 1, camonitor updates with a new entry containing a time stamp, which I assume is the time at which the processing occurred. However when I do caput foo.PROC 1 again, camonitor doesn't update. This has me thinking that it is just for monitoring value changes and not meant for monitoring processing. If we want to know if a record has been processed, it is better to use TPRO. Please correct me if I am wrong.
Andy
Re: Does camonitor update when the record processes? Johnson, Andrew N. via Tech-talk
Prev: Re: IOC in Docker not responding to caget from another host Michael Davidsaver via Tech-talk
Next: ODP: Failed connection using e3-s7plc to Siemens S7-1500 Mateusz Nabywaniec via Tech-talk
Prev: Re: Plotting images in Phoebus Kasemir, Kay via Tech-talk
Next: Re: Does camonitor update when the record processes? Johnson, Andrew N. via Tech-talk
