Subject: EPICs archiver appliance, exporting DESC field in the JSON
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Fri, 29 Oct 2021 22:34:41 +0000
Hey All,
I am wondering why the getdataattime endpoint doesn’t seem to return some of the meta data type fields like DESC or EGU?  I tried to go into the policies.py file and add in some more fields to export but not sure I am doing it in the right spots.  These are the two parts in policies.py that I thought would need to be changed to handle the other fields.  Although I am still not sure why the getdataforpvs is able to export the meta data fields.
# Define a list of fields that will be archived as part of every PV.
# The data for these fields will included in the stream for the PV.
# We also make an assumption that the data type for these fields is the same as that of the .VAL field
def getFieldsArchivedAsPartOfStream():
                return ['HIHI','HIGH','LOW','LOLO','LOPR','HOPR','DRVH','DRVL'];
if "RTYP" not in pvInfoDict:
                                pvPolicyDict["archiveFields"]=archiveFields
                else:
                                pvRTYP=pvInfoDict["RTYP"]
                                if pvRTYP=="ai":
                                                archiveFields=['HIHI','HIGH','LOW','LOLO','LOPR','HOPR']
                                elif pvRTYP=="ao":
                                                archiveFields=['HIHI','HIGH','LOW','LOLO','LOPR','HOPR','DRVH','DRVL']
                                elif pvRTYP=="calc":
                                elif pvRTYP=="calcout":
                                elif pvRTYP=="longin":
                                elif pvRTYP=="longout":
                                elif pvRTYP=="dfanout":
                                elif pvRTYP=="sub":
                return pvPolicyDict
Prev: RE: Failed connection using e3-s7plc to Siemens S7-1500 Miklós Boros via Tech-talk
Next: RE: Does camonitor update when the record processes? Wang, Andrew via Tech-talk
Prev: RE: Does camonitor update when the record processes? Wang, Andrew via Tech-talk
Next: Re: EPICs archiver appliance, exporting DESC field in the JSON Shankar, Murali via Tech-talk
