Hi Alex, Ibrahim,
Thank you for the suggestion - I had seen the omega i series IOC, and was planning to use that as a base if the need for developing a driver arises. Looking through the i series manual it seems there are some similar commands to those used by the Pt series,
but the protocols are not a 1-to-1 match, which likely means at least some development work will be required. Thank you for the links they will both come in helpful.
Best,
Jakub
I am guessing the Omega Pt series communication is different from the Omega I series? Here is an internal link to the protocol file for the Omega I series IOC if you have not already seen it:
https://gitlab.nsls2.bnl.gov/EPS/omega_i_series/blob/master/protocols/omega-CNi32.proto
This should tell you whether or not they are similar.
Alex
Hello Jakob,
We use CNI3253-C24-DC for rack temperature control applications. We use simple StreamDevice commands to read temperature and write setpoints based on the following manual:
omega_CNi16_communications.pdf (lbl.gov). Let me know if you want further information.
Ibrahim
On Behalf Of Wlodek, Jakub via Tech-talk
Sent: Monday, November 8, 2021 4:57 PM
To: [email protected]
Subject: EPICS support for the Omega Platinum Series PID Controllers
Before I begin making plans to develop a new driver for this purpose, has anyone developed EPICS support for the Omega Platinum Series of PID controllers?
The specific model I am thinking of is the
CN8PT-445,
however, based on my preliminary research it seems that the communication protocols are shared between the models in the Platinum line:
If anyone has had a chance to work with one of these and develop an EPICS driver for it, please let me know!
- EPICS support for the Omega Platinum Series PID Controllers Wlodek, Jakub via Tech-talk
- RE: EPICS support for the Omega Platinum Series PID Controllers Saleh, Ibrahim via Tech-talk
- RE: EPICS support for the Omega Platinum Series PID Controllers Sobhani, Bayan via Tech-talk
Re: How to access PSI Elog data from other web clients Wang, Lin via Tech-talk
<2021>
2025
2026
StreamDevice checksum methods Josh Fiddler via Tech-talk
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
