Subject: RE: Access motor controller target positions of other axes in asynMotorAxis::move
From: Mark L Rivers via Tech-talk <[email protected]>
To: Laurenz Rettig <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 12 Nov 2021 22:56:27 +0000
Hi Laurenz,
Ø  This deferred move option, and the saving of the target positions however does not seem to be part of the basic model 3 driver templates (asynMotorController), no?
Correct, this capability was not abstracted to the base class, it is implemented only in the XPS driver.
Ø  Is there any documentation on how to actually use it? I.e. how do I tell the driver that I want to do a deferred move, and how do I initialize the actual move then?
As far as I can tell it is not documented.  I do use many XPS units, but I have never used this feature.  I just looked at the source code, and I cannot figure out how in fact it is used.  My reading of the code is the following:
-          The XPS controller class has a bool member variable movesDeferred_.
-          movedDeferred_ is set in XPSController::setDeferredMoves(bool deferMoves) to the value of deferMoves.
-          If movesDeferred_ is true then when an XPS axis is told to move it just caches the new position.
-          When setDeferredMoves() is called with deferMoves=false and movesDeferred_=true (i.e. a true to false transition) then all of the motors are moved to their cached target positions.
What I don’t understand is what software calls setDeferredMoves().  It is not called from the iocsh functions in XPSController.cpp, or indeed from any code in motorNewport/newportApp/src.  This code was written at Diamond, so someone there may know.  But I am not sure if they use the XPS anymore.
It would be easy to implement in the database and the driver.  You just have a bo record called deferredMoves which writes its value to a parameter in your driver.  The writeInt32 function in your driver just calls setDeferredMoves which implements the logic outlined above.
But you need to decide how you want your driver to work.  Do you want it to work so that when any axis is moved it just tells all the other axes to go where they already are?  Or do you want to really cache the moves?  In that case you do the following:
-          Set deferredMoves to True
-          Tell each axis where to go, it caches the value
-          Set deferredMoves to False, which causes all of the motors to move at once.
Sent: Friday, November 12, 2021 8:43 AM
To: Mark L Rivers <[email protected]>; [email protected]
Subject: Re: Access motor controller target positions of other axes in asynMotorAxis::move
Hi Mark,
thanks for your answer, this looks exactly like what I need. This deferred move option, and the saving of the target positions however does not seem to be part of the basic model 3 driver templates (asynMotorController), no?
Thanks, Laurenz
On 12.11.2021 14:37, Mark L Rivers wrote:
Hi Laurenz,
  • In the communication with the controller, I have to provide the target positions of all axes at once, if I want to get it moving correctly.
Your asynMotorController class has access to all of the axes.
You can look at the Newport XPS driver for an example of how to do this.
That driver has the option of "deferred moves".  This means that as each axis is told to move the desired position is cached.  When that flag is cleared then all of the axes begin to move at the same time.  Note that this is tied to the concept of motion "groups" in the XPS, so the implementation may need to be different for your driver.
asynMotorController and asynMotorAxis also support the concept of ProfileMoves.  For this the motion path for each axis is defined in a waveform record.  The time per motion element is also defined, which produces the velocity for each axis in that element.  Then the controller is told to execute that motion profile, so that all the axes can move on a complex trajectory in N space.
From: Tech-talk <[email protected]> on behalf of Laurenz Rettig via Tech-talk <[email protected]>
Sent: Friday, November 12, 2021 3:58 AM
To:
[email protected] <[email protected]>
Subject: Access motor controller target positions of other axes in asynMotorAxis::move
I'm working on a motor driver (Model 3) for a SPECS manipulator
controller. In the communication with the controller, I have to provide
correctly. The move function in the asynMotorAxis class only moves one
axis at a time. How can I access the target positions (i.e. the values
of the main motor axes PVs) of the other axes in the
asynMotorAxis::move() function, in order to construct the right command
for the controller? Or is there any better way, like a combined axes
command, or so?
Thanks, Laurenz
Dr. Laurenz Rettig
[email protected]
Emmy Noether Research Group Dynamics of Correlated Materials
Fritz Haber Institute of the Max Planck Society
Department of Physical Chemistry
Faradayweg 4-6                         Tel: +49 30 8413 5225
14195 Berlin, Germany                  Fax: +49 30 8413-5387
Dr. Laurenz Rettig                  [email protected]
Re: Access motor controller target positions of other axes in asynMotorAxis::move Laurenz Rettig via Tech-talk
Re: Access motor controller target positions of other axes in asynMotorAxis::move Mark L Rivers via Tech-talk
Prev: Re: Access motor controller target positions of other axes in asynMotorAxis::move Laurenz Rettig via Tech-talk
Next: Re: StreamDevice Format Converters Ralph Lange via Tech-talk
Next: Re: Access motor controller target positions of other axes in asynMotorAxis::move Laurenz Rettig via Tech-talk
